Changing defuser drive gear on ricoh ft4415 copier
A spring was laying inside the copier after someone took out jammed paper, after changing defuser dirve gear that was damaged need to know where the spring is from
  • Dannodad Jul 24, 2008
    great, beings after I changed the defuser drive gear and tested, working okay-looked and looked to see if spring went anywhere but couldn't see on the other side of those picks but looked the same-so good so far thanks alot, appriciated the help and comments-sincerely
  • Dannodad Jul 30, 2008
    thanks for helping me with the solution that was very helpfull in making the right chose to not worry about the spring since it didn't make a diiference in the copier working perfectly now. this is a very good site and will keep in consideration to tell others and probably if need more help will join the site and get others also-sincerely dannodad
  • 1,326 Answers
Is it a small spring and did you find a broken or missing upper pick-off claw? If so that is where it may be from...Is the cpoier working now?? If so why bother....
Posted on Jul 24, 2008
Paper jam on right rear in ricoh copier
Dust an dirt on feed roller remove back cover an clean with alcahol wipes gears could slso be dust an dirt
Aug 26, 2014 | Ricoh Office Equipment & Supplies
Copier paper jammed
check all the photo sensor,spring ,actuator if the actuator is not back in home position just to mean jam paper / and please specify what the jam code /or where is the lead that says jam paper
Jun 10, 2011 | Ricoh Office Equipment & Supplies
My xerox xc830 prints bout 1/2 page and then stops and the paper light comes on. The paper is not stuck in the machine it is just laying there. How can I fix this problem? I have looked for someone to...
The jamming with the copy half way thru is almost always a broken fuser drive gear. The fuser unit is the part that gets hot as the paper exits the machine. Check the back side of this unit. You will see a gear, or part of a gear that is about 1.5 inches across. Either that gear breaks or the cog inside of it shears off and this causes the fuser not to turn. Very inexpensive part at less than $15 and pretty easy to change.
Part number for the gear if you need it is NGERH0540FCZ3
If you had the part I am sure you could find someone to install it if you don't feel comfortable with doing it.
Good Luck
Oct 29, 2009 | Xerox DocuColor 12 Color Copier
Ricoh CL 7100 fuser jam.
The grinding noise is the clashing of gears. The fuser is composed of 2 rollers, a metal or ceramic with a heater inside (bulb) and a silicon roller to apply pressure. The 'hot' roller is geared and the silicon roller can be geared or free floating. There is at least 1 paper sensor in the the fuser to let the unit know whether paper is there and there when it should or should not be. Sometimes, the sensor gets slightly dislodged and can actually cause a jam. If you are hearing a gear clash, the paper is being pushed through the machine and instead of being pushed through the fuser, it stops because the fuser rollers are not turning. The rest of the machine keeps pushing, crinkling the paper.
If there is crinkling, then gears that drive the fuser need to be checked. It is this gear cluster and/or the fuser that need to be replaced.
Aug 03, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Paper jam lite is on
There is a plastic post inside that a spring connects to that probably broke off, it is part of the plastic frame.
what I do to fix that install a screw thru the rear frame and attach the spring to the screw.
If you open the clamshell like you are removing a jam or replacing the toner cartridge. You'll see a black sponge roller on the bottom of the machine, just to the right all the way in the back you'll a metal plate with white gears inside it that is what the spring is connected to. If you press down on the gear, you'll feel the spring tension if it is still connected.
It is a very common problem for that model
Apr 11, 2009 | Canon Office Equipment & Supplies
Can't find printer jam inside printer
the small piece of paper is definately inside.or while pulling the paper out you have disturbed the allignment of the gears.clean the gears of the paper feeder.
Aug 16, 2008 | Samsung CLP-510 Laser Printer
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Prints a couple of pages - then jams
Well, for now it seems to be fixed - I opened up the paper tray and there is a little part that grabs the paper on the front of the tray - kinda sticky - I just took a paper cutter and put a couple of scratches on it and it is grabbing the paper for now. I do have some of those to use for replacements - but I had just changed it about a month ago and don't think it needed to be changed out again - they usually last quite a while. So, we'll see how long this lasts. We do a lot of printing on this thing and it has been a great printer - maybe we are just wearing it out!
May 20, 2008 | Ricoh CL4000DN Laser Printer
My copier makes a noisy sound
Check the crumpled paper. If it has an image, it has reached the drum and is crumpling at the fuser unit (part that gets hot). If that is the case the fuser gear and drive gear need to be replaced.
May 01, 2007 | Sharp AL 1215 Black and White Copier
Paper jam.....
I think you might have a timing problem, ck. and clean reg. and all feed rollers, possible chultch slipping that drive the gears?
Feb 09, 2007 | Ricoh A2018D Black and White Copier
41 people viewed this question
k24674
jasbo
jasbo
