Question about Saeco Vienna De Luxe Espresso Machine
Circuit card? mirran, wow, never heard of that piece. probably something i'd need services i assume?
How do i fix scv motor circuit in toyota rav4
fix? (replace it) or repair the valve it self. what is FIX.?
no country,no engine (a dieseL)
no year. wow !
did you scan the PCM with as real scan tool?
post the DTC error if you have one.?
you do know that DTC's can be false right?, and caused by other failures.
The FSM covers this ever heard of a factory service manual.
get one, read the pages on topic,
Feb 14, 2015 | Toyota RAV4 Cars & Trucks
Toaster wont stay down
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
Jan 12, 2015 | Breville Vtt002 Polished Stainless Steel 4...
Popping sound heard,will not come back on.sound heard when tv was being turned on
Some component failed, probably in the power supply section. Not something you are going to fix unless you are a tech. You can try and open the back and confirm damage to the power board. And possibly buy another board on ebay, but be carefull. Some parts sold there are bad .... This assumes that the set is out of warranty.
Apr 02, 2010 | LG Televison & Video
I've just installed XFX GeForce 6800 graphics card
Not enough graphics card for WoW. Here are the System Requirements,
http://www.worldofwarcraft.com/info/faq/technology.html
Nov 18, 2009 | XFX GeForce 6600GT, (128 MB) Graphic Card
Saeco Incanto Sirius S Class
Take off the top of the machine, look at the printed circuit card and see if you can see anything that is broken.
Look at the fuse in the machine to see if they need to be reset.
Best regards
/Mirran
Oct 17, 2008 | Saeco Incanto Classic Espresso Machine
Coffee dispenses extremely slow
try to change the grinder to little more coars, if it not help then i think it can be something with the printed circuit card.
Best regards
/Mirran
Sep 21, 2008 | Saeco Vienna Espresso Machine
Resevoir leaking on Saeco Trevi(like Vienna)
There are no screw to be removed, you have to take off the plastic ring in the water inlet. Take a screw driver and set it between the chassis and the water inlet.
Hope this will help you.
/Mirran
Aug 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Loud ratchet sound - coffee tamping problem perhaps -
I think you have a leakage in your machine, it can also be your printed circuit card there is a short circuit.
Try to take off the top and look inside the machine.
/Mirran
Aug 18, 2008 | Gaggia Syncrony Compact Coffee...
Same problem with gaggia
Did the machine stop after a while?
When the rinsing cycle run you have to let it go to the water tank is empty and the machine **** air in the system, then you fill up with new water. If it not reset then i think there are something with the printed circuit card.
Let me know if you get your machine to run again.
/Mirran
Aug 06, 2008 | Gaggia Titanium Espresso Machine
Video cards
The 260 gtx is a nice card but ATI just came out with their new cards and the Radeon HD 4850 is faster for about $100 less than the 260GTX.
But WOW uses an older graphics engine and low poly count models with that cartoony look. WOW will run great on some fairly old hardware so if he is using that computer for WOW only and is running SLI then there is no reason to upgrade. He probably has the resolution maxed out and the detail settings maxed out. If he is playing on a 32" 720p widescreen TV then the resolution should be set to a maximum of 1280X768. The rest of the settings should be adjusted to maximize the experience to your liking.
Some LCD TVs to add lag because of the image processing that is hapenning behind the scenes, some TVs have a gaming mode that minimizes this lag. Also your internet connection could be the culprit causing your lag.
In the end you do not need an new video card to play WOW. If he wanted to play Crysis with high detail then that would be a different story.
Jul 08, 2008 | Computers & Internet
Saeco Vienna De Luxe Espresso Machine Logo
18 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
