Question about Brother IntelliFAX 2800 Laser Fax
Error #77 how to fix the error 77?
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
Hi. My Stanley IntelliTape 0-77-008 has an 'error'
Mine did the same thing. To fix it I extended the tape all the way out. As I retracted the tape it started working. Try it and let me know if this worked for you.
Jul 17, 2011 | Measuring Tools & Sensors
Error 77 message
The 77 error is caused by a fuser temperature sensor. The following steps can be used to possibly reset the Intellifax 4100 77 error.
1. Unplug machine then wait 15-20 minutes.
2. Hold down menu key. Plug in machine.
3. Release menu key at maintenance message.
4. press 91 then set button
5. press 99 then set button
6. Machine will warm up.
7. Press Reports key, then press 1. This will test if the machine can
print.
If these steps do not reset the error the thermal fuse would have to be replaced by a repair technician.
Jul 22, 2010 | Brother IntelliFAX 4100 Laser Fax
MACHINE ERROR 77
You have a defective fuser unit, not heating up.
Jun 22, 2010 | Brother IntelliFax-4100e Fax
Why sfc scan performs only 77%?
when you start sfc scan because operating system having problem and its try to fix but some how its not able to fix using this command so do one thing please repair os
May 10, 2010 | Microsoft Windows Vista Home Basic Edition
Error 77
Error 77 is fuser error . Shut off the power for 20 minutes . If that didn't reset the unit , then you need a new part . Call the local dealer to ask about new part price .
please rate !
Apr 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Machine error 77
the fuser unit (fixing unit) not registering heat requirement. The heat roller or the thermistor sensor is defective.Remove fuser and check roller, if good replace sensor, reinstall fuser and reset machine.
Aug 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother MFC-8500 Fax Error 77
Error 77 is a fuser error. If resetting the power doesn't work, then the fuser is bad and it will need replacement. Repair should cost around $200-250.
Jun 13, 2008 | Brother MFC 8500 All-In-One Laser Printer
Intellifax 4100 machine reporting error 77.
Error 77 is a fuser error. If shutting off the power for up to 20 minutes doesn't reset the unit, then you will need a new part. This repair could cost up to $200.
Jun 11, 2008 | Brother Office Equipment & Supplies
Brother IntelliFAX 2800 Laser Fax Logo
276 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
