NO CONNECTION WHEN CONNECTING TO ROUTER ONLY WHEN CONNECTED TO THE MODEM .
  • 68 Answers
Your router is already configured?
Posted on Jul 23, 2008
Does not connect 2 internet
Are you getting any error messages? Is your computer plugged directly into a modem, or is it connected directly to a router. Is the computer connecting to the internet using a wireless network card? If connected directly to the modem, shut off the modem, wait a few seconds and restart; also reboot your computer. If that does not work, go into device manager If you're running windows xp - it can be found by going into control panel - system - device manager and see if your network card is listed without any x's or other markings which indicate a problem with the device. If your network card is indicated with no markings, and it is not working, try downloading and reinstalling the drivers for your system's network connection device (you can get that from your system's support page). If your plugged into a router, or if your connecting to the internet via wifi, try shutting off and restarting the router. Reboot your computer and see if that works. If not, you might need to download and install a firmware upgrade for the router. This is relatively simple, and the instructions and appropriate download file can be found at your router manufacturer's support page. Try these and see which works. Good luck!
Dec 22, 2010 | Computers & Internet
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
Was working ok, now cannot get online using belkin modem-router. Says I am connected to my network, "signal strength excellent" but no wireless connection. Using the Belkin Modem router I am unable to...
please try to reset your router.
on the back of the router there is a little hole where you can insert a pen or a paperclip. hold it pressed in for 30 seconds and then release.
wait 10 minutes and try to connect to internett again (after connecting to the wireless net ofc)
May 28, 2009 | Computers & Internet
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
D link wireless router dir 300. connecting to modem and pc and system tells me that the ethernet connection is not correctly connected ... tried over and over again ... and it just does not work.. thanks...
If the problem is on the side of the modem, the best bet is to unplug your router, reset your modem (through power cycle or reset button), then plug the ethernet cable from the modem into your router, then plug your router back in.
Jul 26, 2008 | Computers & Internet
Wireless Connectivity lost
Greetings Roxie
Are you using XP or Vista?
The default ip address for a Netgear 192.168.0.1 - the default user is 'admin' and the default password is 'password'. Is it possible for you to run an ethernet cable from your PC to the router or from your laptop to the router so we can address its configuration?
Once you have connected the cable, wait about 30 seconds and then open Internet Explorer. In the address bar type 192.168.0.1
At this point the login to the router should come up. If it doesn't report back and let me know. If it does - log in using the default info I listed above. Verify that your connection type is DHCP. From there go to the wireless settings page. Make sure that wireless is enabled and make note of the name (SSID) of your network. Also take note of what channel you are broadcasting on. By default it is probably 6 but you should probably change it to 11. You can also enable or disable the security encryption from this page but lets disable encryption if it is not already disabled.
Once you have verified these items are present and enabled, save the routers configuration. Disconnect your laptop from the router. Unplug the power to the router. Unplug the power to the modem. Make sure all of the lights on the modem go out. Stand tall and sing our national anthem (wait about a minute) and then plug the modem back in. Once the online light has gone solid green plug the power back into the router.
Now go to your laptop and observe the little computer icon in the lower right by the clock. Does it indicate that there are networks available? If so - double click on it to see the available networks. Make sure you are connecting to YOUR network (the SSID we took note of earlier). If it says connected - you should be OK. If it says anything else let me know what it is. Good luck!
-C
Jun 20, 2008 | Dell Dimension 8200 PC Desktop
When I try to reinstall my router I can't get beyond the first step as the disk thinks our computer is not connected to the internet when it is. It convinces my computer that it is no longer connected....
Step 1: Turn off your computer, router, and disconnect the power to the modem.
Step 2: Connect one cable between the modem and the router's internet port
Step 3: Connect another cable between the router and the computer.
Step 4: Turn on the computer, then the router, then the modem - in that order.
Step 5: Now try running the setup disk.
Explanation: The modem has a security feature that disallows more than one device from connecting to it at one time. Once a specific device is connected, the modem expects that device to be connected at all times. If you unplug your computer from the modem and plug in the router without disconnecting the power to the modem, the connection will be rejected. This probably explains the reason for the error message you were receiving.
Furthermore, you do not need the installation disk in order to install your router. Open your browser and type http://192.168.1.1 in the address bar. A username and password screen will appear, the default is usually admin/admin for both, but if that doesn't work just try admin in the password field. When you have successfully logged into the web utility, you will be able to alter the settings at your discretion. For the most part the router will work upon proper cable connections, however you will want to enable security features to prevent attackers from gaining access to your computer.
May 04, 2008 | Computers & Internet
Zyxel P660HW - Wireless Router adsl modem set up poblem
Check in network settings that the two computers have not the same IP address.
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
