Question about Dell Inspiron 1501 Notebook
PHONE OUT I CAN NOT CALL OUT IT CLICKS AND SHUT OFF
    Genius:
  • 2,028 Answers
If you believe this is on your end, try reinstalling the drivers or software that you're using. If this doesn't work contact your provider to see if it's a problem on their end.
Posted on Jul 23, 2008
Sunroof wont shut
have problems or sensors sw open and closed
Apr 07, 2014 | 2003 Chevy Blazer - Xtreme Blazer - Speed...
Troubleshooting Nuova Simonelli espresso
The water sonoled
You have to despatched it ,clean it you will find small break's there
Mar 23, 2014 | Nuova Simonelli Mac 2000 Espresso Machine
For about a week i had to turn key off and on several times in order to start. leaning towards fuel pump; hear clicks no hum when i turn key on, checked shut off and it is not tripped; hear click comi
That's it, that's the definitive answer-it clicks in the tank? The pump is bad, and will need replacing. It should turn on for about 2 seconds to pressurize the fuel line and system with key on-that is the hum you refer to.
Nov 28, 2013 | 2003 Ford Expedition
1990 7.3 ford diesel wont shut down
You need to determine if the problem is in the ignition switch or the fuel shut off solenoid in the Injector pump. As you stand in front of the truck facing the engine, the wire that goes to the FRONT connector on the DRIVERS side top of the injector pump will be the shut off solenoid.
turn the key to "run" and then disconeect that wire, if it "clicks' then the problem is most likely the ignition switch. If it doesn't then run a jumper wire from the positive post of a bettery to the connection. If it clicks then the problem is the ignition switch, If it doesn't, then the solenoid has failed. the fuel shut off solenoid is available and not hard to change. Just be sure to pay attention to to the spring and how it is assembled. You can purchase the fuel shut off solenoid from mid west fuel injection, there may be other places but I know they have it. Ignition switch should be available form most any auot parts store.
Sep 18, 2011 | Ford Econoline Cars & Trucks
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
Lights work, but starter clicks - will not start- battery okay!
sounds like a bad connection,or a bad starter,if you can get under it and smack starter with a hammer,it may be stuck....check connections first... iif it doesnt take off then you need a starter....if it was running fine when you shut it off.. not been sitting for long while,knocking when you shut it off,or over heated..
Feb 02, 2010 | 2001 Jeep Grand Cherokee
Nozzel from the gas station clicks off but tank is not full
Are you putting the nozzel all the way in the inlet? Try putting it only part way in so the back wash doesn't hit the shut off sensor on the nozzel.
Jun 23, 2009 | 2002 Nissan Xterra
Clicking noise in intrepid
Check on what relays are under there.
Oct 20, 2008 | 1997 Dodge Intrepid
32" model# F32668
The F32668 uses the CTC203 series chassis and I usually see 2 problems when the set will not run. The first is poor solder joints on a small coil near the horizontal output transistor, but if thats the case the set tends to run for a while and randomly shut off. When the set clicks and never runs I usually find that the flyback (high voltage) transformer has shorted out inside. In this case the flyback should be replaced by an experienced tech.
Aug 05, 2007 | RCA F32668 32" TV
Tv wont turn on
You probably have a bad flyback transformer (high voltage). You might want to get an estimate to find out if it is worth repairing. Stargazer
Jan 20, 2007 | Sanyo DS31590 31" TV
Dell Inspiron 1501 Notebook Logo
15 people viewed this question
Alun Cox
