Question about AKG SolidTube Professional Microphone
Akg mic buzzing
Mic keeps buzzing all of a sudden
  • famii Sep 16, 2008
    why microphe is buzzing. is't coz of interferance of sounds..??
  • famii May 11, 2010
    i just want 2 know why the microphone is buzzing.
Constant unrelenting hum?
check the fuse housing and make sure it is setup for your local voltage(120/240)
Posted on Nov 28, 2008
  • 682 Answers
If it is not droped down vionetly-your cable or your jack make the problem----try with another cord.
Posted on Jul 28, 2008
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Mar 18, 2011 | AKG C4000B Professional Microphone
What is the switch for on the Phantom power unit at the end of my AKG C747?
Hi,the switch for the phantom power on the microphone is to activation of the mic.Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantompoweronthe mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
Oct 20, 2010 | AKG C747 Professional Microphone
How can you open an AKG 220 perception mic to repair it? the mic got knocked over and still works, but the inside seems loose, moving around from side to side.
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
May 13, 2010 | AKG Perception 220 Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Oct 06, 2009 | AKG Perception 200 Microphone
Akg c3000b Low output all of a sudden
Buy the Caig Labs De-Oxit kit and clean up/treat the XLR connections on the mic itself.
Apr 27, 2017 | AKG C3000B Professional Microphone
AKG 414 crackle
Had the same problem. Check the ground (earth) is attached properly to the mic. This will cause the signal to be interrupted and can also cause a phasing problem. A lot of techs don't check that when you send them for repair
Nov 12, 2008 | Audio Players & Recorders
AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
Jun 08, 2007 | AKG Perception 100 Microphone
AKG SolidTube Professional Microphone Logo
358 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
