Question about Canon CLC 1150 Color Copier
Canon 1150 E020 04E0 Code error
We were copying and the error code E020 04E0 came up and will not work. What can we do.
  • dtillotson10 Dec 31, 2008
    I have the same error code except the on the display screen it saids to turn switch off then switch on. But it's not correcting the problem
  • wertel Feb 13, 2013
    where the black toner sensor? for cleaning
  • 67 Answers
Change all 4 developers plus blow clean both developer sensors you can find these sensors next to the black developer assy it has one screw
Posted on Jul 24, 2008
    Problem Solver:
  • 13 Answers
Step 1
Clean the Black Color Sensor
If Prrblem Solved OK otherwise
Go to Display- Density And observe Black Color density If it is less Add some toner in DP Do initK if Density is Too high take 10 to 20 Black copies by taking hopper out
Observe densk again If it is near 0 init K Problem willsolve
(You need to clean Bk toner sensor after every operation during this process)
Posted on Nov 06, 2014
Le blog developer ne marche pas ou la cellules des demi atr et sale
Posted on Jun 04, 2012
3 Suggested Answers
  • 4 Answers
SOURCE: E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Posted on May 07, 2008
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
Error code E020 04E0...there's an error in the developer unit...check the developer unit and see if it's working properly...
Jun 23, 2009 | Canon CLC 1150 Color Copier
E0000 0132 error on Canon CLC 1150
this is the fixing error indication reset it * 2 & 8 simultaneously * Copier>Function> Clear>Err>OK .Restart the Machine
Jun 20, 2009 | Canon CLC 1150 Color Copier
Canon clc 1150
9 times out of ten that means you need a new drum when it does print does it look ok?? if yes then its definatly the drum it measures the voltage on the drum when its worn this code happens sorry
Jan 16, 2009 | Canon CLC 1150 Color Copier
Error code 5400
go online and type in following information"
canon printer errors code 5400
enter
rod
Dec 22, 2008 | Canon CLC 1150 Color Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
Nov 25, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
Canon CLC 1150 Color Copier Logo
905 people viewed this question
old marine
old marine
Corne Viljoen
