Question about Whirlpool Duet GHW9150P Front Load Washer
Error code flashing F 06 code how do i fix?
  • gunhill-12 Jul 24, 2008
  • toom10 Jul 28, 2008
    code F-6 comes on tryed to unplug still comes on
  • 5,911 Answers
The following link explains the "F06" error code:
This is a motor speed error. It could be an indication of a failed drive motor, failed Motor Control Unit (MCU), failed Central Control Unit (CCU), or interconnecting wiring. I would check the motor windings first. If the motor checks good, the majority of the cases point to the MCU. Read through the instructions and take the readings as recommended to be sure. If you need further assistance, please let me know. I hope this helps.
Posted on Jul 26, 2008
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
How to fix mx-c311 error code e7-06?
The Causes
Compressed image data abnormality. HDD connection trouble when HDD is installed.try to check and see wether connectors are connected properly
. Remedy
If the job at an occurrence of an error is a FAX job, check the FAX PWB. Check connection of the MFPC PWB and the HDD. Replace the MFPC PWB.
Jul 16, 2014 | Sharp MX-C311 Primary Transfer Belt Unit
"service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Jul 07, 2011 | Sub-Zero 650/SRH Stainless Steel
Washer shuts off and flashes code 06
ive had this error code before its a drive motor tachometer error it is the same error code in both kenmore and whirlpool when you order to replace the piece it comes in as enitre harness fromthe motor all the way up the side of the machine to the board
Apr 30, 2010 | Kenmore 45081 Front Load Washer / Dryer
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Whirlpool Duet GHW9150P Front Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal De
