Bosh Washing Machine WFX6278gb I think
Machine starts runs for 5 minutes the trips our fuses box. I have been told it is the motor could this be true
    President:
  • 1,462 Answers
Could be - try unplugging motor then try
more likely to be the heater.
take back off and you will see heater.
test with a megga or take wires off, tape them up then try running machine
doug
Posted on Jul 25, 2008
My machine fills with water and before the drum starts to rotate, it blows the fuse.
If your talking about tripping the breaker its designed to trip under load. Yes if something is keeping the drum from turning that put a load on the breaker and trips it..It will keep tripping until there's no over load on the drum...I'm guessing your talking about a washing machine... You can take the belt off the motor and if the motor is good it will turn on but not spin the drum...Then you know the motor is good and something is preventing the drum from turning. And if the motor is bad you can smell a burnt smell if you get close enough to the motor..Hope this helps
Jul 01, 2017 | Washing Machines
My washer doesn't start eventhough the lights is on and the door lock doesn't go on. i unplug and wait for 15-20 minutes and do the same thing. and nothing happens?
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Apr 14, 2015 | Maytag Neptune MAH5500B Front Load Washer
Hello, the machine turns on, seconds later it trips the main fuse boxes, kitchen sockets fuse.
You have a short some place or motor could be shot. Get it checked out by a professional.
time.
Apr 13, 2015 | Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Washing machine starts the cycle runs for about 5 minutes the trips out (seems to short out tripping our eletricity.
you haven't said make or model, however, probability is that the heater is short to earth from mechanical damage usually ie washing coins etc. remove heater and check
Jul 23, 2008 | Bosch Washing Machines
Washing machine
the problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
Apr 05, 2008 | Indesit W 123 Front Load Washer
Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Jan 14, 2008 | GE S8000E
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
May 07, 2007 | Indesit WA 115 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
