posted by gerkingt on Jul 23, 2008
panasonic pt-53wX42, power wont stay on. Turn on, no picture then it will turn off by itself after 5 seconds. The red power button will flash on and off until I unplug unit and start the whole process over again
Solution #1
posted on Jul 23, 2008
I'm no expert, but I'd start by taking a "VERY GOOD LOOK" w/magnifing glass if possible , @ UR Wall Outlet Power Cord. Change to different wall outlet. Ur Power Cord "should" just pull right out of the back of your TV. If nothing in those places, then take off back panel (or part where power cord plugs into TV & AGAIN inspect area around where power cord attached for, yeah, that's right, the dreaded black area around plug-in area. Maybe it's just a bent prong. Any other funny things going on that U didn't mention here? Good Luck Leonard aka quikstudy@cox.net
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Projection Televisions
Email this problem
Email this problem
This Problem Also Relates To:
GE 46GW947 46 in. Rear Projection Television
Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
Panasonic PT-47WX49 47 in. Rear Projection Television
Panasonic PT-47WX42 47 in. Rear Projection Television
Panasonic PT-40LC12 40 in. Rear Projection HDTV Television
Sony KP-48V80 48 in. Rear Projection Television
Sony KP-53S70 53 in. Rear Projection Television
Can you Help with these Projection Televisions problems?
connecting belkin optical cable...
connecting belkin optical cable... Answer This...
Mitsubishi WS-65809 65 in. Rear Projection...
Tv code
Tv code
Hi my tv, a Mitsubishi HD 1080,... Answer This...
Repair Service
Find Projection TV Repairman Near You:
