Question about Toshiba MD20F51 20 in. TV/DVD Combo
Tv Screen Turns blue occassionally while running Toshiba DVD player
Any solutions to fix this... I have run lens cleaning disk.. still not working
TV screen flashes in consistantly BLue or steady for 2-10 seconds.. again inconsistantly.
Any help would be great.
    Problem Solver:
  • 7 Answers
If the flashing is regardless of source, the CRT could be at fault. H to K short. ( heater to cathode)
Posted on Jul 24, 2008
You can see the DVD logo from the DVD player on the TV, but does not load movie keeps showing loading, have switched to different movies same results.
Seems like problem with the lens of the DVD player. You can find a Disk in the store to clean lens (called as Lens cleaner Disk) Once you run this lens cleaner disk, it should start working if there is not a major problem with DVD player. Hope this helps Please rate if you like this solution
Jun 23, 2011 | Televison & Video
My toshiba sd-3205 will not load any of my DVDs anymore, the discs I insert into the player are in perfect condition and have loaded previously when the DVD player was working. it always says...
Probably dirty pick up lens.
Get a lens cleaning disc and run that and see if that cures problem.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba SD-3205 Multi-disc DVD Player
We have a flat screen RCA which has the DVD player built into the TV. It is on the right hand side of the TV. Now, when we insert a DVD, the DVD won't read and play. We get the message "DVD...
Try a different DVD to make sure it's not just a single scratched / damaged DVD.
If it does this for all DVDs, then I recommend returning it and getting a refund / replacement right away before your warranty runs out.
If your warranty is already expired, then you can try one of those lens cleaning disks with a diluted alcohol solution, since it might just be some dust on the DVD laser lens. Most times though, the dvd drive motor is failing and is hardly ever cost effective to repair.
Best of luck and let us know how it turns out.
Jan 21, 2011 | RCA Televison & Video
I have a Toshiba DVD player SD K741. For the past few days, when I load the dvd, I receive a message on my TV screen "Incorrect Disc." What can I do to correct this?
incorrect disk error are common with the user putting in a disc that is not compatible with the player, in most cases it would have been a RW, that was written incorrectly. If this is not the case and it is a original disc you might want to purchase a cleaning dvd witch goes in and cleans the lens.
If that does not work then the unit's lens might be defective at this point.
1. Try other disc
2. try a cleaning disc
If those do not work then the issue is with the lens.
Thanks for your question please do not forget to leave a rating.
Aug 31, 2010 | Toshiba SD-K740 DVD Player
Absolutely you better bet it can, just hook up the cables to the front and select the input on your tv and you should be ok. For the internal DVD try running a cleaning disk you never know it could be just dirty.
Thanks if you like my advice and solutions please use the thumbs above to rate it and give me some feedback as well.
Jan 30, 2010 | Toshiba 23HLV84 23 in. TV/DVD Combo
Toshiba 20hlv86 TV/DVD Combo - DVD not working (not spinning up)
maybe the pick-up has gone,or dirty len?spin motor gone?
1,clean the len
2,replace the spin motor which hold disc
3,replace the pick-up assembly
Mar 30, 2009 | Toshiba 20HLV86 Television
When the DVD is inserted, an error appears
have you tried or have you been using a laser lens cleaning disc ?
if not then the glass lens will need to be manually cleaned with a q-tip and lens cleaning solution
Feb 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
Toshiba MD20F51 20 in. TV/DVD Combo Logo
226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
