Question about Compaq Presario 700 470024-192 Notebook
Dvd-rw drive My computer has lost track of the dvd-rw drive and now i can't open it or even find it in the device manager. Why is this going on and how can i fix it?
    Genius:
  • 2,028 Answers
Usually when this happens, the burner end of the drive has gone out and the drive will need to be replaced in order to fix it. On rare occasion the driver glitch, so, try uninstalling the drivers for the drive from the device manager and reboot. The machine will find the drive and reinstall the drivers. If it still doesn't work, then I'm afraid the drive has failed and will need replaced.
Posted on Jul 23, 2008
Around track 8 in its recording process it breaks up the audio signal so when we duplicate it kick out a error then kicks out the CD's
this could be caued by a few possibilities you might not have select to burn an audio copy or the burning software does not support the burning of audio copies although if it burns a few before being interrupted it probably will support audio burning
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
the other possible reason might be the cd/dvd burner is not getting continuos power during the burn process
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
Jul 06, 2011 | MicroBoards CopyWriter Live (CWL6200)...
My computer won't recognize my NAC ND-1100A dvd/cd rw. i go to the device manager and its not even listed as being attached to the computer. it has power and all the lines are attached on the back, it...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 28, 2010 | NEC ND1100A Internal IDE DVD-RW 4X+ Drive...
I have a NEC DVD RW ND-3530a and my windows xp service pack 3 stopped recognizing it. it no longer reads as a drive. The device manager has it listed with a yellow !. I have tried uninstalling and...
Remove the drive from your computer, and temporarily connect it to another desktop computer.
If it still does not work, then it's time to responsibly recycle it, and spend $40 to purchase a new CD/DVD reader/writer.
Dec 10, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
Where do i look for details of the installed drives for my cd-rw and my dvd/cd-rw. its just a hands on question in my computer repair I class
goto control panel, open device manager... you can find all the drivers that are installed in your computer including cd/dvd drivers....
start > control panel > device manager (for vista & win7)
start > control panel > system > hardware > device manager (for xp)
or
right click on my computer icon, select manage > select device manager
Oct 05, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
How can I find out if my HP Pavilion dv4000 has a DVD burner?
The simple way is to insert an empty disk and try burning the disk with some content. If it burns, that means you have a dvd burner fixed with ur device. Another way which is comparitively complicated is to check the device in the device manager. Right click on My Computer and click on Manage on that. You will get another window opened
In the left navigation pane, you will see device manager. click on that and see your DVD Drive status. If its given as DVD+ RW then you have dvd burner installed in ur system.
Aug 01, 2010 | HP 419320-001 - HP Pavilion dv4000 Series...
Upgraded the BIOS and no more DVD Device manager
If you cannot see the DVD Drive you have lost the DVD drivers....
relode the drivers from your system provided CD and reboot
and even check in the "safemode "network support" by pressing F8 contunisly......as soon as you switch on the laptop ...
Sep 19, 2009 | Acer Aspire 5520-5908 Notebook
I also lost my DVD drive, in my sony vaio VGN-FG58e laptop. It also have Pioneeer DVD-RW DVR-K_17 ATA and the error code is 39. Could you please suggest the solution.
To solve this follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording application
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7)uninstall the drivers for cd drive and dvd drive from device manager and then
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that there is no yellow exclamation on the CD or DVD drive
Jun 14, 2009 | Pioneer DVR-107D DVD±RW Burner
My Samsung DVD RW Drive icon Has changed in to DVD RAM Drive Icon in the My computer, today!!! The problem is that i cannot open any sort of CD's, DVD's Pls!! M in big trouble!! i removed da drivers in the...
is it sata dvd rom or ide dvd rom?
at first remove the dvd rom. check it is primary or secondary slave selected it. then add the dvd rom.
go to the bios options. check the dvd rom position.
selected is secondary dvd rom. check the power cable.
icon can change it does not mater. you need to open the dvd rom.
Jan 29, 2009 | Computers & Internet
DVD Drive does not start
cd opens, but dvd does not open or burns
Nov 24, 2007 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
Compaq Presario 700 470024-192 Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
