Question about Video Game Consoles & Games
Screen says system error. A large E 68 is at the bottom of the screen and the red light on the front of the xbox is flashing.
  • 62 Answers
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them **** up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
Also try removing the HD, and starting it up without it.
Posted on Jul 24, 2008
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Red flashing ring at front of xbox
There are a number of problems associated with red ring. What error code comes up when you start the system? It is located at the bottom of the screen and starts with an E...
Nov 21, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
What is E68 and how do i fix it? when i switched on my xbox 360 a red light appeared in the bottom left of the power switch and a system error appeared on the screen with E 68 what is this and how do...
The E68 error means that your hard drive is either broken or not connected propperly. Turn the xbox off and take out your hard drive and put it back in. When you put it back in make sure that you hear it click at the back of the xbox. then turn it on. if it still doesent work your hdd is ruined and youll have to get microsoft to fix it.
Dec 29, 2009 | Microsoft Xbox Console
One red light - Error: E 68 - Problem code 0110
Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
We offer a repair service.
FixMyConsole
Jun 03, 2009 | Microsoft Xbox 360 Console
One red light flashing error code E74
Is it still under warranty?
Call the company and get an online tech. I had to send mine back...  It took a week to receive a box from the company and about 6 weeks to get it back. I forgot about it! It takes a while, but works well!
Dec 25, 2008 | Microsoft Xbox 360 Console
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
Red light bottom right corner
this means some type of hardware failure and yes it can happen from time to time depending on whats wrong with the system...well i did some quick reserch and they say its a hard drive issue...so luckily you will only have to pay 100 dollars instead of buying a new system....unless you vae a warranty...hope this helps
Feb 02, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
47 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
