Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Parts need a thermostat control for a franklin fridge model#FCR3600D,could you help me please!
  • 41 Answers
Jacoby apliance parts 1-800-698-1049 dan
Posted on Jul 24, 2008
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
Kenmore fridge over pullout freezer. Freezer has snow. Model 59673502201 . Fridge runs, and shuts off apparently normally. Freezer is cold, air blowing (fan?) from behind freezer temp control. Thought...
Please : - Clean up your freezer - set the thermostat to middle - check the fan for malfunction
There are many things that cause your freezer work abnormally.
Nov 07, 2010 | Kenmore Freezers
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Side by side freezer frost in the back and food thawed out....the freezer is a 9 and fridge 5...What should i do? it is a couple of years old...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Jun 13, 2010 | Freezers
Freezer in side by side isn't freezing, but the other part is OK. What to do?
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Oct 04, 2009 | Freezers
Frigidaire side by side works fine for a couple of days then it starts to get warm, milk gets warm n ice starts melting. i unplug for a day n i when i plug it back in tll work for a couple of days...
Sep 25, 2009 | Freezers
Foster freezer keeps going into alarm: (code:DEF).
Check to see if the defrost system is working.
Sep 24, 2009 | Freezers
Sides of freezer are hotter than normal. no air sound when closing door,is this a defroster problem?
First check the condenser fan underneath near the compressor. It should run when the compressor runs.
Sep 24, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
My upright freezer won't self defrost. Frost builds up right awa
Sep 19, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Unable to adjust temperature with control dial
YOU WILL most likely need a new thermostat for the unit. What evere tripped the breaker apparently welded the contacts on the thermostat. take the model number and the serial number and the thermostat you have here's the part and the model number for you 21 # 216788100 Control-temperature please be sure to rate this soilution after your done. Have a happy new year>
Jan 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
87 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
