OK... YOU HAVE TWO POSSIBILITIES... EITHER THE LEVER ON THE TOP COVER BROKE OR THE ONE ON THE PRINTER CARTRIDGE...
IF ITS THE ONE ON THE TOP COVER THEN YOU NEED TO REMOVE THE LEVER HANDLE COMPLETELY AND GET A PLYERS AND USE IT TO TURN THE METAL THE LEVER IS ATTACHED TO OR FIGURE OUT WHERE THE THE LEVER GETS THE MACHINE TO LATCH AND USE A FLAT HEAD SCREW DRIVER AND SLIP THE LATCH... THEN CONTACT KONICA MINOLTA AND PURCHASE A NEW LEVER...
IF ITS THE TONER LEVER THATS BROKEN... YOU ARE GOING TO HAVE TO GET A PLYERS... TAKE A FIRM GRIP ON THE TONER AND REMOVE THE TONER IN THE SAME WAY THAT YOU WOULD IF THE LATCH WAS THERE... IF ITS BEEN PUT IN ODD THEN IT MIGHT BE STUCK... YOU MIGHT NEED TO USE A FLATHEAD SCREWDRIVER ON THE ENDS TO HELP THE PROCESS ALONG...
USER MANUAL
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
