Question about Honeywell Heating & Cooling
I have a BARLO 2-Port Motorized Valve MODEL No 2PV-2 with 5 Wires Blue Green/Yellow Brown Red and Graey. Can i replace it with a 2-port Honyell Valve and if so which one please. JOHN.
  • 7 Answers
SOURCE: changing thermostat matching wires trouble
Brown my friend is for the 4 way valve solenoid, that is if you have a heat pump, ( it uses freon for heating instead of natural gas) perhaps you got the wrong thermostat, if you have a brown you need a thermostat for a heat pump, a regular thermostat is not going to have a brown connection.
Posted on May 08, 2008
Cyril J
  • 45 Answers
SOURCE: maytag 2 speed replacement motor
you may have wrong part , post model serial , and part number that you have i will look them up
Posted on May 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: Replace thermostat
Typical color codes in Florida are;
white to W1 for heat
yellow to Y for compressor
red to R-RC-RH for power in
brown to W2 and or emergency /auxillary heat
green to G or Fan
orange to reversing valve(o/b)
blue to common.
You can open the control panel on the unit to verify these colors and components.
Posted on Feb 21, 2009
peyton32034
  • 410 Answers
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Posted on Mar 16, 2009
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Satchwell cylinderstat has brown, blue and earth (green/yellow) wires. which is te common and which is connected to the orange on a Honeywell V4073A 3 port valve. I presume the green yellow goes to the...
The colour codes are as follows:
Brown = Line / Active
Blue = Return / Neutral
Green/Yellow = Earth / Ground
It is likely that the Brown and Orange would be connected together but not 100% sure.
Sep 21, 2010 | Plumbing
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
2 Orange --- Orange
4 Red --- Blue
6 Yellow --- Green
8 White --- Brown
Apr 11, 2009 | Computers & Internet
1994 mercedes 500sl dash cluster problem
Hello, I don't have a picture but maybe this will help,
red/yellow-4
brown/white-1
brown-2
blk/yel-2
pink-11
green/white-13
green-12
brown/red-18
brown(small)-17
blue/brown-10
blue/green-7
blue/white-14
3 5 6 8 9 not used
I hope this will help.
CYA Gator241
Dec 08, 2008 | 1994 Mercedes-Benz Mercedes Benz Sl Class
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Need help with wiring a pioneer deh-5
You do not have the entire Pioneer model number listed, so I cannot provide you with the wiring info for it.
Bu here is the wiring info for your jeep.
Constant 12V+ Pink/Yellow  Switched 12V+ Red/White  Ground Black  Illumination Orange/Brown  Dimmer Black/Light Blue  Antenna Right Front  Front Speakers 6 1/2" Doors Left Front (+) Dark Green  Left Front (-) Brown/Red  Right Front (+) Purple  Right Front (-) Dark Blue/Red  Rear Speakers 5 1/4" Roof Mount Left Rear (+) Brown/Yellow  Left Rear (-) Brown/Light Blue  Right Rear (+) Dark Blue/White  Right Rear (-) Dark Blue/Orange **from the12volt.com
Best of Luck.
Oct 31, 2007 | Alpine CDM-7874 CD Player
Heating & Cooling Logo
49 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
