Hi
You could try to go to computer properties
device manager
scroll down to mouse and pointing devices
then un install the touchpad
then restart laptop and windows hopefully will reinstall it correctly on startup
if this does not work
then go to the laptops computer manufacter's website and download another driver and install it
making sure that it is the correct one for your make model and operating system
as i don't know which laptop you have maybe if an acer www.acer.com go to support/downloads
and search for the driver if hp www.hp.com support/downloads etc
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
