Question about Sanyo DS31520 31" TV
Sanyo ds31520 tv
When i switch my set on it sounds like its about to come on then switch itself of again.
  • 2 more comments
  • SKYE123 Jul 24, 2008
    WHEN I SWITCH IT ON IT COMES ON FOR ABOUT A SEC THEN SHUTS DOWN
    TRY RESETING IT DONT WORK
    YET TRY THAT LAST NIGHT MY FRIEND
    THANKS FOR THE TIP WILL GET ON IT ASAP
    Genius:
  • 1,665 Answers
It is your power supply fault. Better take it to an authorized service station to repair.
Posted on Jul 24, 2008
    Master:
  • 382 Answers
Try to hard reset the device ,that is Unplugg the device for 30 mins or an hour and then replugg the device..Hope this helps you...!! Thank you....
Regards!!...
Posted on Jul 23, 2008
  • 1 more comment
  • Natesan Sabesan
    Natesan Sabesan Jul 24, 2008
    yeah that is the reason why i prescribed you the hard reset of the device??..DId u try it buddy ??..
  • Natesan Sabesan
    Well if you are familiar with tv service you can check the horizontal output
    transistor,it might have gone bad(short circuit)and it all is going to
    take to get the set back running,sometimes the output trasformer
    damages the transistor and both have to be replaced,first just change
    the transistor and if it blows up again then replace the transformer,if
    you are not too familiar with servicing a tv be safe and call for
    assistance from a servicer...Hope this will help you..
    Regards!!!!...
  • Natesan Sabesan
    Please try to change output transistor which will surely help you my Friend..Cheers!.. :)
    Master:
  • 555 Answers
Have you tried turning it on from the remote instead?
No audio on sanyo ds31520 after replacing vertical IC.
Replacing vertical output IC won't poise this type of problem. Check the voltages at the audio output section.
Jun 22, 2012 | Sanyo DS31520 31" TV
I need the code for a sanyo TV please
it is for t-255 sanyo tv.... press menu key on tv set& sleep button on remote handset simultaneously...again press sleep key on remote handset.
Jan 18, 2010 | Sanyo DS31520 31" TV
Can you switch from tv to video input on sanyo ds31520 tv without a remote
no you require the remote or a universal remote or sometimes a cable remote that has been programmed to work the volume on the tv set will have an input button .
Sep 29, 2009 | Sanyo DS31520 31" TV
Have a Sanyo tv model DS31520. Won't turn on. push power button, nothing. checked fuse on board-o.k. Power to circuit board. Any ideas what to check next?
Sounds like the switch is missing the mark behind it. Take the back cover off and see if the back of the push ON switch has been worked loose from pressing.
Hope this helps bud.
Jul 24, 2009 | Sanyo Televison & Video
My sanyo tv has no picture no sound 31"color tv
my grand son unplugged my sanyo tv 32in from wall while on no wi have no picture and no sound
May 17, 2009 | Sanyo DS31520 31" TV
Sanyo tv model DS31520..is it an HD tv?
You can view the specifications here:
Sanyo DS31520
I found no mention of the needed ATSC digital tuner so you need to acquire a converter box to receive broadcast signals after the changeover. Cable and satellite reception are not affected.
I reviewed the available converters and chose the Zinwell ZAT-970.
Jan 14, 2009 | Sanyo DS31520 31" TV
Sanyo DS31520- high pitched whine, picture is fine
sounds like bad solder connections on ground of the inputs radioshack has a cheep solred gun and solder make sure set is unpluged
Dec 03, 2006 | Sanyo DS31520 31" TV
No picture only a high pitch sound
Yes,it can be repaired,sometimes for no reason components fail and they need to be replaced,if you are familiar with tv service you can check the horizontal output transistor,it might have gone bad(shorted out)and is all is going to take to get the set back running,sometimes the output trasformer damages the transistor and both have to be replaced,first just change the transistor and if it blows up again then replace the transformer,if you are not too familiar with servicing a tv be safe and call for assistance from a servicer,if you take the set to them it should be expensive.Let Us know how it goes or if you need more information.
Nov 08, 2006 | Sanyo DS31520 31" TV
Sanyo DS31520 31" TV Logo
88 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
