Question about Amana PTH153B50AM Air Conditioner
I have an Amana PTAC unit model no. PTH153B50AM. It will not heat, but the fan runs continuously in the heat mode. The unit has a label that says it has a manual reset for the heater, but no direction as to where it is.
    Sergeant:
    Novelist:
  • 185 Answers
First unplug the unit......Take the front cover off, take the wire screen off where the front fan is there is 4 or 5 screws that hold the plate that was under the screen. The electric heating elements are under that plate between the evaporator coil and the front blower wheel. It will lift straight up and give you access to the elements. In the electric heating element area there is a limit switch with a red or black button in the center of it push it to reset the limit it is on the right hand side by the controls. I wish I could find a picture to show you but I couldn't find one. It is not easy to get to... Hope this helps.
Posted on Feb 12, 2011
SOURCE:
I have an amana ptac model pth153B50AM it does not seem to cool much at all but I do hear the compressor come on.Before i cost myself a couple thousand dollars can anyone tell me is this fixable?
yes it is fixable does the blower run? I would pull it out take it outside and wash with hose the outside coil and inside coil make sure you clean the outside coil real good on both sides. this may solve your problem.
Jul 30, 2014 | Amana PTH153B50AM Air Conditioner
I have an Amana ptac unit that continually runs the heat cycles on and off but never shuts off
Check to see if there is a fan switch...if not, then more than likely, the fan relay is stuck closed.
Dec 17, 2013 | Heating & Cooling
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
My unit just started blowing cold air only when its on heat, what can i do??
To getproper heat, keep your temp setting at 30+ degree and also mode in "heat "position.If still no heat, check your heating sensor for closed circuit by an OHMsmetre.It it's with RV, check power to RV
Dec 16, 2010 | Amana PTH153B50AM Air Conditioner
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Jan 23, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Charging a ptac
Either or, they both are the same ends but different routes..
Sep 08, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Nov 18, 2007 | Amana PTH123B25AJ Heat Pump Air...
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH153B50AM Air Conditioner Logo
946 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
