Question about Teac DC-D2831 CD Shelf System
I have a TEAC Stereo DC-D2831. The power button stays in the "on" position. The CD deck drops down after loading cds to play. Can't get them out, or even turn them around to play others.
  • 1 more comment
  • labcerb Jul 23, 2008
    Pulling the electric cord did not work - the power button is still stuck in the on position.
  • labcerb Jul 24, 2008
    No, it didn't work. I did manage to get the front cover off, but the inside is all circuit boards and wires.
    There is no way that I can get to the power button at all.
  • milaena May 11, 2010
    have cover off see circuit board. How to find power button connection to clean it? CD goes in, does not play. Drppoed, moved 5x, in storage. I think it got rumbled about. Thanks, Milaena m_milaena@msn.com
    Genius:
  • 2,028 Answers
This particular stereo is obsolete, so finding a repair man may be hard to do. If you can find one, it may cost you more than what it's worth to have it fixed, especially since this machine sold for less than $100 new. It might be time for a new stereo.
Posted on Jul 23, 2008
    Genius:
  • 1,689 Answers
2 possible reasons:
the switch contact may have some corrosion that the switch is left ON, if you can open the front end of the stereo, try to clean up the contact using a common eraser
if the switch uses a spring to engage and disengage the contact, the spring may be broken and needs replacement, or a part of the button lock is stuck, TLC may work for it too.
good luck
  • marlon john madrid
    marlon john madrid Jul 25, 2008
    labcerb, good job to get the cover off, since you see all circuit boards, that would mean your power button is not mechanicalso just try to check the contact (like the controller of a ps2) and clean it up with some lighter fluid (since it quickly dries up, then gently rub the surface of the board where the contact hits with a regular pencil eraser.
    good luck
    Master:
  • 382 Answers
Did you drop it or Dash it somewhere because only that can cause the Cd deck to go out of postion..??...
Thank you..
  • Natesan Sabesan
    Natesan Sabesan Jul 23, 2008
    If thats the case then you should replace the power button which is stuck..Try to call up a service person and get the power button replaced.!!.Thank you..
    Regards!!...
    Master:
  • 555 Answers
Try resetting it by pulling the power cord and then replugging the unit.
I have a TEAC DC-D2831 Digital Compact Hi-Fi System. The Cassette Portion does not play any more. Where/who can I get to fix it? Thank you
I am in Chicago and another ex Teac manager is in New Jersey who is still doing repair work. Where do you want to send it?
Jun 08, 2011 | Teac Audio Players & Recorders
My Teac DC-D2831 has actually two problems: 1) the muting light won't come off during CD mode and 2) the 3 CDs often come loose in the tray and get shuffled around or stacked up. Help?
check your remote 4 damage. an make sure u dont have efx or nothing turned on while u r n cd mode. o yeah cds have different thickness u mite need 2 use skinny cds. some cds u can see thur n some u cant
Mar 14, 2011 | Teac Audio Players & Recorders
I have a TEAC W-450R Stereo Double Reverse Cassette Deck. For some reason, the REC/PLAY II side will not operate. It has not for some time. In fact, that is why I believe I mothballed it some years ago....
I have not seen those to a large extent due to their value not being worth a repair. I did work on them at Teac though. The capstan motor of the right side deck sound like it is burned out. I have some motors here so it is just a matter of if you want me to work on it or not. I get a lot of units in all the time- I am Skywave Tape Deck Repair in Chicago area.
Feb 22, 2011 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
How do I get my Teac DC-D2831 CD Shelf system to come on? Nothing comes on? Not the radio, cd, cassett nor the turntable.
I was having the same problem, I read my users manual and found that there is a time button on the front of the unit itself. My husband must have pressed ithe last time he used it. Works fine now.
Nov 13, 2009 | Teac DC-D2831 CD Shelf System
Will cursing help open the cd player- if not can you help me figure it out along the line how do you preset the 20 fm stations
turn the power off hold down the cd open close button switch power on if that doesn't work its busted
Nov 05, 2009 | Teac DC-D2831 CD Shelf System
System is frozen
try using the reset button on the back of the set
Mar 06, 2009 | Teac DC-D2831 CD Shelf System
My mothers Teac DC-2831 skips when playing cds. We have used cd cleaning disc, and even compressed air. Nothing! What can we do? If we have to take it to a repair shop, can you give us one in the Los...
My DC-2831 started doing the same thing -- and continued, despite repeated cleaning with a CD-player cleaning disc. Oddly, older CDs would play OK, but brand new ones -- commercial CDs, not homemade -- would promptly begin skipping or lock out altogether. Solution?
Unplug the system, lock the turntable stylus arm into place with the attached C-clamp, then carefully unscrew the back and side panels. Once the innards are exposed, gently lift out the CD-player and visually inspect it for hidden dust, pet dander, even fur can get inside there and gum up the works, and that's something NO CD-cleaning kit can ever reach.
Once you've inspected and cleaned the CD-player of all visible dust and dirt, carefully replace the player, make sure it's seated properly within the shell, then reattach the side and back panels in the exact reverse order as you removed them. THIS IS CRUCIAL: if you don't put the stereo back together in the exact reverse of how you took it apart, you'll have components off-kilter, screws that won't go back in (and leftover screws are a sure sign you're screwed it up!) and your CD-player will be even more temperamental than ever. Word to the wise.
If all this sounds too scary, then you'll have to either live with the crappy CD-playing performance, or get a new system. You can't replace the CD-player unless you buy an entire new system. WARNING: these all-in-one turntable systems are VERY RARE anymore, so don't get mad and kick your TEAC or toss it out or give it away on a whim. You'll play hell trying to find a replacement.
Hope this helps!
Dec 04, 2008 | Teac DC-D2831 CD Shelf System
Changing the clock time
small button just right of LCD screen push watch push once for hour, puch tunener bar up or down for hour. push button to change to minutes, push tunerbar up or bown to change minutes
Aug 30, 2008 | Teac DC-D2831 CD Shelf System
TEAC MC D90
try different cd's my has the same problems. maybe due to early era of cd player. some cd's work ok. use as an amp with outboard cd player. good luck
Aug 18, 2008 | Teac DC-D2831 CD Shelf System
TEAc HMX-760 "CD Drawer" was removed
you lost the cd tray timing,caused by force- eject,so you need proper alignment,you,needs specialist.
Feb 05, 2007 | Teac DC-D2831 CD Shelf System
Teac DC-D2831 CD Shelf System Logo
222 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
