Question about Umax Astra 2200 Flatbed Scanner
SCANNING Once i have scanned a document or photograph on the computer screen the image appears but has all lines going through what I have scanned. I am not that technically minded and have tried a few things but cannot not get rid of these lines
  • Maxgsd Jul 28, 2008
    Tried what you suggested and no this did not work. Still lines on scanned image. Do you have any other suggestions please.
  • 490 Answers
Clean the glass surface with Isopropyl Alcohol (IPA). Dont use any other solvent. You can also use a well wrung wet cloth to clean the glass.
S. Mohan
Posted on Jul 25, 2008
  • Mohan Sriraman
    Mohan Sriraman Jul 29, 2008
    When lines appear in the scaneed image, the first step is to clean the glass. Specs of dust sticking will give a line in the output. If it still persisits, check if the inside of the scanner glass has dust. Does the line thickness (any line) vary with different levels of brightness? If so it is definitely dust problem. If the thckness remains the same, for a specific line, it could be failure of the sensor. It is also possible there is some hardware error.
    S. Mohan
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
L want to scan a document with hp office jet 4355 how do l get scaning option from my computor
1.Turn on your computer and wait for it to boot up, then turn on your printer.
2.Locate the " HP Image Director " icon on your computer and double click it.
( This icon was placed there when your printer was installed on your computer )
3. A screen will appear showing the scanning options available on your printer.
4. Place your document or picture on the printer's glass top.
5. From the HP Director screen, click on the appropriate button to start the scanning operation.
The scanner will perform two passes, the first; is to preview your document or picture and to
make changes, if necessary, the second; is the final acceptance of the document or picture
and save it on your computer.
All scanned pictures can be viewed in the HP Photo Gallery and the My Pictures folder
Documents can be viewed in the My Documents folder.
I hope your scanning goes well.
Feb 07, 2011 | Office Equipment & Supplies
I have a HP Photosmart 2575 xi all in one printer and I need to be able to scan documents and photos. I have no idea how to do it. How do you scan these things. I use the printer and the copier but have...
1. Turn on your computer, wait for it to boot up, then turn on the printer.
2 Double click the "HP Photo Imaging Director" icon on your desktop ( placed there when your
printer was installed on your computer ). A menu screen will appear showing the scanning
options of the printer.
3 Place your document or photo on the printer's glass top and close the lid.
4 From the menu screen, click on " Scan Picture " or " Scan Document "
When "Scan Document" is selected, a secondary screen will appear from which you will have to
make choices. After making your decisions, click "Scan" from the listed screen.
When "Scan Picture" is selected, one scanning pass will be performed, another pass will be
made after you view the result of the first pass.
Scanned pictures will go to the HP Photo Gallery and your "My Picture" folder.
Scanned documents will go to your "My Documents" folder.
Good Luck with your scanning operations!!
Jan 21, 2011 | HP Photosmart 2575 All-In-One Printer,...
How do i scan a document?
Hi, it all depends on the printer your using.
How to Scan a Document on a Multi-Function Printer
A multi-function printer with a scanner makes backing up your important documents easy. The scanner function of the printer allows you to translate a paper document like a receipt or title deed into an electronic copy that is stored on your computer. Once you have an electronic copy of your document, you can process and manipulate the document as you would any other electronic file. Follow these steps to scan a document on a multi-function printer:
Connect your multi-function printer and computer. Power them up.
Select the side of the document you are going to scan. Give the document a once-over, checking for any flaws that you do not want transferred into electronic form.
Open the printer's lid. Place the side of the document you want scanned face-down on the glass plate of your multi-function printer's scanning bed. Align the document to your satisfaction.
Close the printer's lid carefully. You may want to weigh the document down with another sheet of paper to prevent it from shifting.
Choose an appropriate scan resolution. You may have to do this using the controls of your printer or on the computer, depending on the model and software.
Press the scan button to start the process. This can be done on the printer itself or on the computer.
Preview the scan on your computer monitor. You should be able to make minor changes to the scanned image if needed.
Save the scanned image if you are satisfied with the result. Try again if you are not satisfied.
Tips & Warnings
Scanning documents at high resolution and low data compression will produce the best image quality at the cost of file size.
Not happy with a scan? Re-check the alignment of the document and try it again. Discard the duds when you get a scan that works for you.
Using harsh cleaning chemicals such as acetone or benzene can damage your multi-function printer. Abrasive cleaners are also not good on the machine, particularly the glass surface of the scanning bed.
....How to Scan a Document on an All-in-One Printer?
Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
Turn on your all-in-one printer and computer. Check the connections between the two machines.
Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
Close the printer's document lid slowly so the document does not shift position.
Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
Push the scan button. You may have to do this on the printer itself or on your computer.
Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
Accept the scan and save. Return the original document to a safe location.
Hope it helps..
Oct 28, 2010 | Office Equipment & Supplies
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    I dont know how to scan
    HI, The easiest procedure to scan a document using your scanner is open Paintbrush that is installed with your operating system. Click on File Menu at the top left corner of your screen, then select "From Scanner or Camera". Once you have selected the option, you will be prompted for your scanner. Select the installed scanner and go on scanning the image/document placed on the glass bed of your scanner. Once the scanning has been completed, save the image file.
    Cheers!
    Mar 06, 2010 | HP Photosmart C5180 All-In-One InkJet...
    How can i use my pixma mp210 printer to tranfer a picture into my pic file on the computer
    Hello my friend,you mean to scan a photo and save it on your folder?
    If yes
    1. You run the application MP Navigator from your dekstop (or from Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.)
    2. When the one-click mode screen has opened, click the Switch Mode button to switch to the navigation mode screen
    3. Point to Scan/Import and click Photos/Documents (Platen).
    4. Place the document face-down on the platen, and select Document Type.
    5. Click Specify... and set the preferences as required.
    6. Click Scan and it should start scanning
      When scanning is completed, the Scan Complete dialog box opens. Select Scan or Exit. Select Scan to scan the next document, or select Exit to end.
      When scanning is completed, the scanned image appears in the Thumbnail List area.
    7. Edit the scanned image as required.
    8. Click Save or Save as PDF file.If you choose just Save and box will appear to specify the destination folder, file name and file type(usually images are .jpeg .jpg ;) ).
    9. And click Save and your done.
    Scanning Photos and Documents
    Jan 15, 2010 | Canon PIXMA® MP210 Printer
    How do you get the Canon Pixma mp500 to scan?
    Scanning images,
    About Scanning images
    You can scan images from the machine to a computer without printing them and save them in popular formats. Scanned data saved on your computer can be processed using image processing software. Furthermore, you can use the OCR (Optical Character Recognition) software to convert scanned paper documents to text data.
    * Before scanning
    Before scanning images, confirm the following :
    - Are the necessary software (MP Drivers and MP Navigator) installed ?
    If the software is not installed, install it.
    - Does the document to be scanned meet the requirements for an original to be set on the Platen Glass ?
    - Is the machine connected to a computer correclty.
    Confirm that the connection between the machine and the computer is physically secure.
    Scanning Methods.
    A) Scanning Using the MP Navigator
    MP Navigator enables you to scan in documents loaded on the Platen Glass and view images saved on your computer or on a memory card. Scanned documents can be previewed and easily printed and edited according to your needs.
    You can use the supplied application softwares to edit or print the document you have scanned.
    Windows : Double-click the [MP Navigator 2.0] icon on your desktop to launch MP Navigator.
    Mac : Select [Applications] from the [Go] menu, then double-click the [MP Navigator 2.0] icon to launch MP Navigator.
    You can launch the following application software from the MP Navigator.
    * Easy-PhotoPrint (Photo Printing)
    * ArcSoft PhotoStudio (Photo image editing)
    * ScanSoft OmniPage SE ( Converting scanned document to text)
    - This application software may not be supplied with teis machine in some country.
    Note : If you did a [Custom Install] and only installed the MP Driver and MP Navigator, these application software were not installed and thus cannot be launched. To launch any of the above application softwares from MP Navigator, do a [Custom Install] once again to install them.
    For detailed operations of the MP Navigator, refer to the Scan Guide.
    B) Scanning Using the Operation Panel of the Machine
    You can scan documents to your computer by using the Operation Panel.
    Important : Do not insert or remove USB cables when scanning images with the machine connected to a computer, or when the computer is at sleep or standby mode.
    *If you are using Windows XP
    The program selection screen is displyed the first time you press [Color] or [Black] on the machine.. Specify the [MP Navigator 2.0] as the application software to use, check [Always use this program for this action], then click [OK]. From the next time, MP Navigator is automatically started.
    *When using Mac OS X
    For the machine to start scanning when [Color] or [Black] is pressed, you need to set MP Navigator as the starting application software in Image Capture under [Applications] of Mac OS X.
    1) Press [ON/OFF] to turn on the machine.
    2) Load the documents on the Platen Glass.
    3) Select the scan option.
    a) Press [Scan].
    The scan operation selection screen is displayed.
    b) Use Up or Down arrows to select the scan operation, then press [OK].
    Scan standby screen is displayed.
    Save to PC : The document is scanned and saved.
    Save as PDF file : The document is scanned and stored as a PDF file.
    Attach to E-Mail : The document is scanned, and the image is attached to an e-mai using the e-mail application software.
    OPen with application : The document is scanned and displayed on the registered application software.
    4) Press [Color] or [Black].
    The document is scanned. The settings configured from MP Navigator apply when scanning.
    Important : If with some types of original the position and size of the image is not scanned in correctly, please refer to the "Selecting the Behaviour of the Operation Panel with Mp Navigator " in the Scan Guide (on-screen manual). and change the MP Navigator [Document Type] and [Document Size]] to match those of the original being scanned.
    Note : The operation to be performed after scanning the document depends on the scan operation setting you have selected in step 3. For details on how to modify the operation settings, refer tp the Scan Guide on-screen menual.
    C) Scanning from an Application Software
    You can scan an image from TWAIN-or- WIA (Windows XP only) complaint application software and handle the scanned image in the application software. For detailed operations, refer to the Scan Guide (on-screen manual).
    Hope this helps.
    Please rate my response.
    Thanks
    Have a good day.
    Dec 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
    I want to scan a document to my computer
    have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
    Overview of the Basic Procedure
    This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
    Make sure the CX6600's power cord is plugged in.
    Place your materials on the document table.
    Start a TWAIN-compliant application.
    In the application, open EPSON Scan.
    Full Auto Mode:
    EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
    Home Mode or Professional Mode:
    Make settings to optimize images and click Scan.
    The scanned images are sent to the application.
    Save the scanned images in the application.
    Scanning / How to Scan
    Scanning an Image
    Turning on the CX6600
    Placing your materials on the document table
    Starting the software and scanning an image
    EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
    Note:
    You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
    Note for Macintosh users:
    Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
    Caution:
    Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
    Before turning on the CX6600, make sure it is connected to your computer.
    Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
    You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
    You can start EPSON Scan in the following ways.
    * Start EPSON Scan directly as a stand alone application
    * Start EPSON Scan from a TWAIN-compliant application
    This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
    Note; if you are using Windows 98:
    ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
    Start ArcSoft PhotoImpression.
    For Windows users:
    Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
    For Macintosh users:
    Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
    Click the Camera/Scanner button.
    Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
    Note for Windows XP users:
    Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
    EPSON Scan automatically previews the image, and recognizes the document source and type.
    If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
    After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
    EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
    Caution:
    Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
    Note:
    Be aware that clicking Cancel on this screen closes EPSON Scan.
    The scanned image is sent to ArcSoft PhotoImpression.
    Note:
    * Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
    * When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
    If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
    May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
    We have a canon MP610 printer scanner combo, I work in a dentist office and am trying to scan a x-ray. When I do it is'nt picking up the detail very well at all. I think I need to adjust the settings but I...
    the only way to get a little more detail out of this printer with x-rays is to INCREASE the DPI resolution. there are no other adjustments that are abailable.
    The Scan Settings dialog box opens when you click Specify... on the Scan/Import Documents or images screen.
    The Scan Settings dialog box allows you to specify advanced settings for scanning.
    Document Type
    Select the type of document to be scanned. To scan photographs, select either Color Photo or Black and White Photo. To scan text documents, select either Color Document, Black and White Document, or Text(OCR). To scan magazines, select Magazine(Color).
    Document Size
    Select the size of document to be scanned.
    Auto Detect: Detects document size automatically.
    Auto Detect(Multiple Documents): Select this when scanning multiple documents at one time.
    Select Stitch-assist to scan the left and right halves of a document separately and combine them back into one image.
    Reference See the section below for details.
    Scanning images Larger than the Platen (Stitch Assist)
    When you select Custom, a dialog box in which you can specify the document size opens. Select a Unit, then enter the Width and Height and click OK.
    Important When you select Auto Detect the position or size of the image may not be scanned correctly depending on the document. In such a case, specify the document size, such as A4 or Letter according to the document to be scanned, and align a corner of the document with the corner at the arrow of the platen.
    When you select Auto Detect(Multiple Documents) allow 3/8 inches (1 cm) or more space between the edges of the platen and the document.
    If not, some images may not be scanned at the correct positions and sizes.
    You cannot select Auto Detect(Multiple Documents) or Auto Detect when Document Type is Text(OCR).
    Scanning Resolution<<<<-------------------------------------------------------------<<<<<<<<<<
    Select the resolution at which to scan documents. The following scanning resolution can be specified:
    Text(OCR): 300dpi, 400dpi
    Others: 75dpi, 100dpi, 150dpi, 200dpi, 300dpi, 400dpi, 600dpi
    The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail. At high resolution, scanning takes longer and file size becomes larger than usual. See the section below for details on resolution.
    this should answer your question , feel free to post here agian if you need more help.
    Regards, and thank you for using fixya.
    Oct 23, 2008 | Computers & Internet
    Umax Astra 2200 Flatbed Scanner Logo
    129 people viewed this question
    Top Umax Office Equipment & Supplies Experts
    Tony
    Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
