Question about Sharp R-1470 Microwave Oven
Fan button Does not turn on fan. Control panel? Process to access it.
  • 143 Answers
Take out the screws holding the sheet metal case on.
Posted on Jul 23, 2008
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Fan blows when doors open
One of the three door switches has failed and will need to be replaced. You would need to access behind the control panel to check them and or replace it. Good luck
Feb 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson mw9090ss just stopped while heating something
proceed with common sense, clearly, and logically.and fix it .God bless you
Microwave overheats and keeps turning off All microwaves have some sort of a cooling fan to help keep the magnetron and controls at a tolerable level. Most OTR models will usually use the vent motor for the cooling fan also. Countertop units have a small fan behind the control panel somewhere. Either way, if the cooling fan is not working and heat builds up, it is going to open a thermostat. On some makes, this thermostat might re-set itself as soon as the temperature cools down. Other makes, you will have to replace the thermostat or fuse.
If this is your microwave oven repair problem, you will need to check the operation of the fan. Below in the component testing chart, you will see how to test the fan. Also, if possible, make sure the fan is not obstructed somehow and not turning. Also check your fan relay at your control board for voltage, if no voltage, replace control board. This fan should come on at the same time any cooking starts.
Aug 02, 2012 | Emerson MW9090SS Microwave Oven
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 01, 2011 | Samsung Microwave Ovens
My DSpacemaker JVM 1640BJ fan doesn't work
I would wonder if you've had trouble recently with the cooktop lights?
Such failure can cause damage to the control board (which we repair) which can cause either fan to act improperly.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Also I would wonder if it's the internal cooling fan or the hood vent exhaust fan?
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
Many brands have a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I replaced the light bulbs but they still do not come on and the vent fan will not come on either?
the fan and the surface lights are run through the control via the touch pad. if you tried to replace the bulbs without unplugging the unit 1st you probably shorted the board. this can be checked by lowering the touch control panel by first removing the vent above it to access the panel screw. at this point you can observe the control for burn marks
May 17, 2009 | Hotpoint RVM1325WW Microwave Oven
Vent fan won't turn off
This may be a shorted hood fan TCO (thermal cutout or thermostat) or a problem on the control board.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Atour Web site, we have a videoavailable showing how to remove a typicalover the range control panel assembly in under 5 minutes.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 19, 2008 | Microwave Ovens
JVM1540DM1WW exhaust fan comes on at random times for no reason
I would suspect that your hood fan thermostat is intermittently shorting, or less possibly a relay on the control board is sticking.
The hood fan thermostat (hood TCO) detects excess heat from the stove top and will turn the fan on automatically at its preset temperature.
The one on your model should turn on at 133F and turn back off when the temperature falls below 104F and it should have pink wires attached. (Other models may have different colors).
A failure of either the TCO or relay can cause unwanted operation of the fan.
One way to isolate a bad TCO is to disconnect and tape off the wires on one side. Preferably the side that goes to the fan.
If you or a friend does this, be sure the wire is taped over and secure so its metal will not touch anything inside (including the chassis) and so that the wire will not be damaged.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can unplug the oven, swing the control panel down, find and pull the pink wire on the hood TCO that goes to the fan, tape its connector over and tape the wire to another wire clear of any metal or moving parts.
There's probably no need to disconnect any other wires to get to the TCO wires..
Then reinstall the control panel, plug the oven in, and use it for a couple of days.
If the fan does not come on at unwanted times, then you know the TCO is bad and can order one.
If the fan still comes on at unwanted times, then you have a problem on the control board,
We repair these smart boards on a regular basis for customers nationwide by mail with our guaranteed $39.95 service with a full one year warranty.
Dec 15, 2008 | GE Advantium 120 Convection/Microwave Oven
Buttons for light and fan
I had the same problem with the three buttons pushed in.  Here's how I fixed it:
1. turned off power at breaker or pulled plug 2. Unscrewed two screws on top of unit 3. Removed exhaust vent cover/grill by sliding it to the left and out 4. Unscrewed single screw above LCD control panel 5. Removed control panel assembly by sliding it up and out and rested it on a box so wires wouldn't pull out 6. The control board behind the three buttons had dislodged from the clips 7. Secured the control board with the clips and added a little superglue to clips and extra foam padding to keep it from moving. 8. Screwed the control panel back in, powered up, and tested 9. Reattached the exhaust vent and screwed it back in
Dec 01, 2006 | GE JVM2070 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
