Question about Microsoft Windows Vista Ultimate Edition
Boot sequence order for dc5700 micro tower
I am having probs with rebooting , i am a novice with pc , advice me pleaze
I have problem with booting
Posted on Jul 25, 2008
I have a packard bell desktop computer and i would like to make it boot from cd 1st so i can fix my windows
you need to change boot order in your bios. when you boot check at bottom of screen to see what you need to press to enter bios, you may need to fast. It will probably be F1 or F2 or delete. once in bios got to boot order and put cd drive first.
Oct 11, 2012 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Hp dc5700 micro tower using winxp wont boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jun 04, 2012 | HP dc Computers & Internet
Reboot with cd
Put the cd in the drive and the system might be set to boot from it automatically.
If not, Put the cd in the drive and watch your screen for which key it says to hit to change the Boot Order or Boot Sequence, when you see the message, hit that key. This is a temporary change only good for the current boot cycle.
If you want to make a permanent change to the boot order or boot sequence, reboot your system and watch the screen for which key it says to hit to enter the Bios or System Setup. When you see the message, hit the key. Tab over to change the boot order or boot sequence. Normally you would make the CD/DvD drive 1st and the Hard Drive 2nd, because if the hard drive fails or has a problem you can always insert the cd and it will boot from it first. Just make sure when you boot that there is no music cd or movie dvd in the drive or you will get a message saying something to the effect of Unbootable device.
May 14, 2012 | Computers & Internet
I have acer aspire 3000+ and cant change bios setup to boot first from cd rom and erecovery doesnt work
Why can't you change the bios setup to change the boot order or boot sequence?
Also you can change the boot order or boot sequence temporarily by just rebooting the laptop then watch the screen for which key it says to hit to change the boot sequence or boot order, then hit that key when you see the message.
May 08, 2012 | Computers & Internet
What can I do to fix this problem, my gr 500 is telling me to reboot and select proper device or insert boot media in selected boot device
You need to go into your Bios or System Setup and change the boot order or boot sequence. It sounds like you might be trying to boot from a Network or Lan. It could be that you are trying to boot from the CD drive but instead of having a operating system disc in the drive you might have a movie or music cd in the drive.
Reboot the computer and notice what key the screen says to hit to get into the Bios or System Setup and hit that key. Change your boot order or boot sequence. The best sequence is to have the CD Drive 1st and the Hard Drive 2nd. Changing this in the bios or system setup will make the change permanent. Just make sure when you boot the computer that nothing is in the CD drive unless you have a repair disc or operating system disc in it.
You could make a temporary change but then you will have to change it every time you boot. If you notice the screen when you boot it also gives you the key to hit to change the boot order or boot sequence. This will allow you to change it just for this time that you are booting.
May 03, 2012 | Gateway 500GR PC Desktop
How to reboot from boot sequence
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. You want to boot from the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Dell XPS M1730 Laptop
Cannot read any disk
maybe the panel wire inside the computer may not installed properly.Check ur computer at the same shop.
Feb 23, 2009 | HP RT865UTABA - HP Promo dc5700 micro...
Recovery disk needed
reboot
on reboot, enter BIOS setup, F1 Esc, whatever the prompts say
and change the boot sequence to a valid drive.
This may not work since you did not say what occurred to __kup the boot sequence
Sep 20, 2008 | Insignia D300a PC Desktop
Trouble booting
I have a problem printing pictures using vista ultimate while printing lables for dvd's the paper rolls out without a picture
Jul 23, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
