Question about Lexmark Wheelwriter 10 Series II Typewriter
Tabbing My IBM Wheelwriter 10 Series II seems to have something wrong with the tabbing. When I hit the tab button it brings the wheel all the way to the end of the typewriter. Is there a way to fix the tabbing so that it only indents?
  • 475 Answers
Have you set a tab where you want it to stop? If it wont keep tab settings after being turned off it may need batterys.
Posted on Jul 25, 2008
Turn the sound off of IBM Wheelwriter 3.0 Series II
The only sound you can turn off is the optional spell check feature which is done by holding down the code button (left of the spacebar) and then hitting the number 1. Any other beeps cannot be turned off.
May 08, 2014 | Lexmark Wheelwriter 6 Series II Typewriter
Ibm wheelwriter 6 Series II
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Apr 28, 2014 | IBM Lexmark Wheelwriter 6 Series II
My ibm wheelwriter beeps 1 time when i tab
Does anything else work? It is possible your right margin is set to close to the left margin. Try tabbing all the way to the right, set the right margin, hit the return and then hit the tab. If it beeps and goes all the way to the right, try setting some tab stops and retry the test.
Jan 06, 2014 | IBM Office Equipment & Supplies
I have an IBM Wheelwriter 15 Series II and the ribbon needed replaced so we replaced it, now when you try to top it just types the top half of the letters??????
Make sure both tabs on the rear of the cartridge are in their respective slots. If that does not work, try pushing down on the black platen roller on both ends. If one side is not locked in place, you will get half letters.
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
IBM personal Wheelwriter 2 margins not clearing
Return to the L. margin, touch the mar rel key top key on L. of the keyboard, backspace to location where you want the L. margin, touch the L. mar key. Put some WD40 on the silver shaft that the carrier slides on.
DickyO
Jun 24, 2009 | Lexmark Wheelwriter 5 Series II Typewriter
How do I clear the tabs on this IBS wheelwriter 1500?
Space the carrier all the way to the right, press and hold the tab clr key. press return this will clear all tabs rt. of the L. margin
Feb 06, 2009 | Lexmark Wheelwriter 1500 Typewriter
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 10 Series II Typewriter Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
