LG DVD 5095 DVD Player
Problem for LG DVD 5095 DVD Player
LG DVD RECEIVER LH T-9654
By shelby4844 on Jul 23, 2008
My DVD Player/Receiver has locked up. Will not come on, can not get tray open to get dvd out. What could be wrong with it. It's only about 2 yr old.
Solution #1
posted on Jul 23, 2008
Not Rated)
Shuttle83
Rank: Guru
Rating: 85%, 982 votes
Hello shelby4844,
Is the front panel coming on? I ask because if it is not this is indicating possible power supply failure. In this case the switching power supply might be having a problem. I would suggest that you have someone who is skilled in electronics work on this problem for you since the power supply delivers current and voltage that could be hazardous to your health. Now that being said, this problem could be cause by a blown fuse, first unplug the DVD player, open it up, and find the fuse. The fuse will look like two metal caps separated by a glass or ceramic housing containing a strand of wire. Once you find this fuse. Take it out and measure it with an ohmmeter, the fuse should read 0 ohms (dead short from one cap to the other.  If the fuse is not bad then one of the other components may be bad, at this point, the testing should be done by someone who is skilled in electronics.
I hope this help,
Thank you,
Shuttle83
Was this helpful?
Yes
No
Popular Solutions for LG DVD 5095 DVD Player
Questions and Unsolved Problems for LG DVD 5095 DVD Player
Do you recommend LG DVD 5095 DVD Player?
Answer
Answer
need to make a philips dvp 3310 dvd player region free
Answer
hi i missing a cord to my wireless system it is the DC power cable from head uint to the transmitter... (More)
Answer
i moved the unit to a other room. i only swithced the power off removed the cabels at the back and... (More)
Answer
The DVD player is connected to TV, TV as well as DVD payers are switched on. But after 1/2 minute... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
