Question about Dell XPS 200 PC Desktop
COMPUTER CRASHED DELL XPS 400. IT STARTED WITH PROGRAMS INSTALLED THAT I DIDNT DOWN LOAD AND ALOT OF POP UPS.THE WINDOW LOGO APPEARS, BUT DOES NOTHING AND AT THIS POINT THE KEYBOARD IS NOT WORKING. I CAN GET INTO F 2 AND F12 BUT THE SYSTEM WILL NOT GO INTO SAFE MODE. ERROR...FLOPPY DISKETTE FAILURE, IN WHICH I DONT HAVE ONE ON MY PC. I ALSO TRIED RE-INSTALLING WINDOWS WITH THE DISK AND NOTHING. THANKS
To go to safe mode press F8 just before windows starts. this works on all versons of windows.
Posted on Oct 17, 2008
Dell XPS 600 turns on, However does not boot. Screen is black....
Do have windows installations disc put it computers cd reader.if windows when windows start from the disc choose to repair go back in time before the accident.
Mar 30, 2013 | Computers & Internet
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
I installed windows xp on a Dell XPS 400 and on a Dell Latitude D505, both are genuine copies of Windows Xp pro. I forgot to save the Drivers before installing the XP. So the ethernet ports don't work on...
Probably the previous download files you have downloaded are corrupted, do a check the downloaded files sizes from source & the downloaded to your PC/Notebook are the same sizes.
1. Download link @ Drivers & Downloads for Latitude D505
2. Dowload link @ Product Support for XPS/Inspiron XPS (Key in your "Service Tag" to locate the exact drivers for your model).
Hope it helps.
May 01, 2011 | Microsoft Windows XP Professional...
When I boot up my PC (Dell XPS 400) and select my user icon, a ''Windows Installer'' pops up and a ''ScanSoft PaperPort 11'' window appears trying to install this ScanSoft program. I then get a pop up...
the pc is looking for the driver of the program,if you have the program disc ,reloading will clear off the message, but if no disc,go to control panel,open =load,remove icom go down list til you find program, then remove
Jul 09, 2010 | Dell Computers & Internet
Dell xps400 branched to the weeds on me. can't even load windows 7 install disk. can't even load in safe mode, runs to where the password screen should come up, then nothing. bad hard drive? drvon, thanks
I didn't understand the first sentence but if you can't even start windows 7 cd then there is a hardware issue (most likely not hdd unless it hangs when it is trying to detect the hard drive) as all the software is on the cd vs reading from the hard drive, if you get to the hard drive and 7 sees it but fails on install then hdd is bad, try finding something called bart pe it's a boot disk you can run windows off of the disk and test the hard drive using western digital diagnostics utility. even more rare you may have a dirty lens in the dvd-rom. there are alot of possiblities.
May 21, 2010 | Dell XPS 400 PC Desktop
Windows won't recognize the HDD in my Dell XPS 400.
hawkdawg
In regards to installing your new harddrive if you are installed a SATA drive the issue is that not all versions of Windows has SATA drives native on the Windows install CD. So during the first part of the install you will need to press F6 to load the SATA drivers of the driver CD. If you do not have it you can download the drivers from support.dell.com
Let me know if you have any more problems or questions
Issken
Apr 13, 2010 | Dell XPS 400 PC Desktop
Problem with startup of XPS 1530
if ur unable enter the save mode...then vista has to b corrupted....install new vista and goto to repair option....
May 26, 2009 | Dell XPS M1530 Notebook
COMPUTER CRASHED?
See if you can get to safe mode. Write back to see if you can, and we will give you instructions on how to proceed from there.
Otherwise you will need a restore or winxp OS installation disk.
Jul 22, 2008 | Dell XPS 200 PC Desktop
Dell XPS 200 PC Desktop Logo
99 people viewed this question
Alun Cox
