Question about SVA-USA SVA HD4208TIIIBU 42" Plasma Monitor
Can't get picture
My screen continues to say aquiring signal, I have hook all cables to my dish box and TV the same as another TV in the house and that is the messdage each time.. The dish worked fine when i had another tv hooked up!
    Genius:
  • 1,139 Answers
Hello matthew95765,
The TV is working, the message is coming from the dish box. What you need to do is to determine if the dish box is connected to the dish and that it has signal at the box, because the message it is delivering to the TV is that it is not receiving signal from the satellite. so you have to check the connection at the satellite and at the box because those are the only point that can generate the error you are getting.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 23, 2008
I have aquired a dish dvr, i do not have the dish servicem however. I want to know if i can still record a program and watch it later. Thank you
It is highly unlikely. The unit unlikely has any inputs other than the coax cable coming from the satellite dish. This will is the same 75 ohm cable connection you see on your tv used with antennas or cable service, but the tuner in the satellite box only decodes satellite signals.
Sorry about your luck. I recall some manufactures such as LG making DVD recorders with hard drives inside them. Those units can capture any analog signal. Another idea is to get a TV tuner card for your computer.
Jan 05, 2015 | Televison & Video
There is no picture on tv
1.is the tv plugged in & getting electric?
2. Does the tv show a raster,a blue screen.
3.is the tv getting an input signal , assuming that the answer to 1 &2 was yes.
4. Is your cable box plugged in.
5. are all the connections into your cable box connected
or did one fall of
6. did you pay your cable bill on time.
If your cable box is bad , the cable company should fix or replace it for free. If you or someone else unhooked the connections,say by tripping over them,the cable company will restore the connections and chatge you a service call fee.
7. do you have dish or direct tv? either of those services will loose picture if it is raining out and picture wont come back until after the storm passes.
8. if you have dish or direct tv, and a branch,a person or an animal, a bird, has fallen on the dish/direct tv antenna, it may have misalligned the dish and it will no longer recieve the satalite signal. THere is a reallignment service
available;dish network charges $95.00 unelse you have insurance,like i do,so it only cost me $15.00 I never had direct tv soi could not say, but dish net claims direct tv is more expensive
You can allign the antenna yourself ,if it is not on a steep roof. You need one person moving the antenna & another person at the tv telling him if the picture is getting better or worse. The dish box comes with a built in signal strength gague for that purpose.
enjoy considering these options and they next time you ask
please enclose all the information that you can so that we have something to go on and work with.
Oct 08, 2013 | Televison & Video
No signal on tv
Your Samsung has an Input Source button on the remote. If you are getting a "No Signal" message, you either have no cable, dish, antenna, or HDMI input to the television or have the wrong source selected. With the television turned on and/or a cable box, dish etc turned on, select all of your sources until a picture appears.
Jan 17, 2012 | Samsung 403T 40" LCD Monitor
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has...
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Jun 27, 2011 | LG 37LC7D 37 in. LCD HDTV
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Dark horizontal line scrolling up from bottom of screen
if you are using a cable box .. then disconnect everything that is feeding signals into the tv ... then get a signal from some other source (like off the air antenna or video camera) ... if the tv still has the dark lines then you have a bad primary filter capacitor in its power supply .. if it works ok off the air and only does it when the cable box is hooked up .. then the cable box has an open primary filter capacitor . ... the dark horizontal bars you see is ripple from the rectified AC power that is not properly filtered ... if the TVs verticle scan rate is 60 hz and the full wave rectified AC amounts to 120 hz ripple then you will see two dark bars across the picture ... since the two signals are not syncronized then they will slip in phase with respect to each other .. thus the constantly moving pattern ..
Apr 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
Direct tv came with apartment. has never worked says NO Signal on the screen I had cable put in but why pay for somethiing that is already included? I have tried everything but since it is not in my...
Try calibrating the antenna to the nearest satellite. The DirecTV box has in the installation menu instructions on how to do this. You'll need some tools like a socket wrench to unlock and adjust the antenna. Put in the menu your global position or your city and select the transponder that gives better signal. If all satellites are out of signal, move the dish until you receive at least one.
To calibrate the dish from the ceiling or wherever it's installed, put the TV volume up until you hear the short "BOOP" sound from the dish location. When you get signal, the "BOOP" will turn to a continuous "beep" with a higher pitch when higher the signal you're receiving. After getting the best signal, switch transponders to see if there's another with better signal, after that, lock the antenna and try watching a channel.
Nov 04, 2009 | Philips DIRECTV H20 DTV Receiver
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Nov 28, 2008 | Philips 42PFL3603D 42 in. LCD TV
SVA-USA SVA HD4208TIIIBU 42" Plasma Monitor Logo
144 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
