Sony DAV-FR8 System Logo
Posted on Feb 12, 2011
Speaker wire connectors where can we get the snap in clips that connect speak to the main unit
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Apr 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1244
Points
10
Call Sony 1-239-768-7691 Parts Department, have your device model ready. They have very good service and for sure have parts for old and new equipment.
Or got to https://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
Good luck.
I have a Brookstone HTiB V1.0 DVD/Receiver. I am trying to find what gauge and type of wire the unit uses. It is bare copper wire on the unit side and RCA connectors on the speakers. Thanks
If you are speaking about the wires to the speakers from the player, you can get any speaker wire the common sizes are 14 or 16, pay attention to the positive and negative or it will sound muddy.
4answers
Bose acoustimas double cube speaker
what the exact model # of the unit..?
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
2answers
How do you disconnect the wire connection from downpipe on peugot 206 to where its clipped to engine
you need a special tool to pull the clips open to release and install new one
2answers
How do I hook up the speakes with 1 main main and one main monitor?
Need more info, how many main speakers and monitor speakers are you trying to plug into the unit?
How do I hook up my lifestyle 20 . I bought it second hand and my speakers have wires.
Hi Mark,
I'm assuming you have the original speaker cables that came with the system (it looks like the connectors on the small speaker side are not standard connectors). If that is the case, the two smaller speakers should connect to the Left and Right 'Output to Cube Speakers' plugs on the larger subwoofer box. A 3rd cable from that subwoofer box should connect from the "audio input" connector on that box to the to the "Speaker zone 1" plug on the main unit.
Plug both the main unit and the subwoofer into power outlets, turn them both on and you should be all set. If you click on the link below, pages 7 - 8 of the owner's guide have a good description and pictures of this configuration. The rest of that guide may come in handy too.
Bose Lifestyle 20 Owner's Guide
I hope this helps,
- Kevin
Need wiring diagram
Step 1 Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system.
Step 2 Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires.
Step 3 Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers.
Step 4 Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation.
Step 5 Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them.
Preparing for the installation
Step 1 Be properly prepared. This is extremely important since you do not want to realize you're missing something in the middle of the installation.
Step 2 Purchase the following: A car stereo wire harness which connects the existing wiring for your old head unit to your new one (this will be specific to BOTH the model and year of your car AND to the make of your new head unit); an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
Step 3 Obtain a guide to removing the dash, doors panels (or whatever compartment the speakers are in), and floor molding of your car. You may be able to find a guide for this online. If not, you can get a repair manual for your car at most automotive stores and online).
Step 4 Gather the following tools: Screwdrivers to fit the job, pliers, wire cutters, wire strippers, a utility knife, sand paper or a file, electrical tape, a 9-volt battery, and any other tools that the instructions for installing the head unit and your car guides specify.
Installation Process
Step 1 Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
Step 2 Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
Step 3 Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
Step 4 Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
Step 5 Put the fuse in the fuse holder.
Step 6 Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
Step 7 On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
Step 8 In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
Step 9 Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
Step 10 Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
Step 11 If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
Step 12 Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
Step 13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. That's all!
Good luck.
2helpful
2answers
External speaker hook-up
Ok, after A LOT of internet research I could not find any solution. So I decided to do a "chop suey" connection.
Went to Radio Shack and bought ...
Insulated Grip 2-1/4"Alligator Clips w/screw terminals 10 (five red & five black)
(A smaller alligator clip can be used if you have a soldering iron to connect the wires.)
30-Ft. 18-Gauge Clear 2-Conductor Speaker Wire
It cost about $15 for everything. Be sure to have electrical tape as well.
Stripped speaker wires to fit through each alligator clip and twisted it around the screw terminals of clip. Tapped screw terminal to cover wiring. Do this for 2 black and 2 red clips.
To install l laid the TV on its back and insterted each alligator clip to firmly fit on each terminal. Because the clips are large it will be a tight next to each other. Be sure to test one line and speaker first before completed the second line and speaker.
GOOD LUCK!
Wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
60helpful
8answers
Bose Cube Speakers separated
Ok…
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
Tools:
small, thin, flat-head screwdriver
large pliers
C-clamp
Instructions:
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
