My 50's RCA flat screen TV has no picture and I already tried replacing the lightbuld.
  • 2 more comments
  • Kialee72 Jul 24, 2008
    Model # M50WH72S
    Thank you!
    Just want to add that when we push the power button the light blinks like it is trying to come on but doesn't. We used to have just sound but now we get nothing except that blinking light. The TV is only a year old, just over the warrantee date. Been through the owers manual and have tried everything.
    Thank you I will try that. Where do I locate these capacitators?
  • Kialee72 Jul 26, 2008
    You were right it was the capacitors. Two were bad and a third was starting to go bad. I had to have a tech come and fix it but at least I knew what to tell him. Works great now! Thank you for your help!
  • 8,617 Answers
I will need the model number of your set in order to help you out with your problem. Please reply to this same post when responding.
Posted on Jul 23, 2008
  • Sonny Berry
    Sonny Berry Jul 24, 2008
    Your model has the ATC 332 chassis which has a couple of comon faults. One is the lamp door switch has a tendency to not make contact. And the other are two capacitors that go bad on the power supply Board they are CP624 and CP647 look at those two capacitors for signs of swelling or a rust color residule on the top . Let me know what you find or if you need more assistance
  • Sonny Berry
    You will have to remove the back panel and you will see the power supply board, it will have the power cord attached to it, and the capacitor location numbers will be stamped on the circuit board next to those two capacitors.
LVDS issue with RCA 46 inch LCD TV
If you wish to get some details; check the site linked here. Pull up older posts.
Reasons for upside down picture are given.
Jul 13, 2016 | RCA Televison & Video
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
50" RCA LED LCD tv. The image is just a blank background with colored lines sweeping over the screen. I've replaced the t'con board and nothing has changed. Any ideas, suggestions? I'd appreciate it.
Your display panel may be bad. If any of the ribbon cables were stressed it could also cause this. There are two other boards that control this. the ysus and zsus. On some tvs they can be replaced and other thay can not. The best way to tell is to try and unhook one at a time and see what the picture looks like. If you can not unhook those boards then the display panel is bad and can not be replaced.
Oct 16, 2015 | RCA Televison & Video
How much does a 50 inch RCA HDTV flat screen bulb cost
Picture and sound went out on my 50 inch tv
Apr 23, 2012 | Televison & Video
2007 35" rca lcd tv L26HD35D has no picture but i
Sounds like it is probably the backlight. Turn the television on and tune to a channel, then try holding a flashlight RIGHT up to the screen and see if you can see a bit of the picture.
Aug 11, 2011 | RCA L26HD35D TV
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
TV screen tuurniing on and off, sound remains on.
If its a DLP set have you ever replaced the lamp? If not I would suspect that first..
Aug 14, 2009 | Televison & Video
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
