Question about Dryers
Ge Electric drier not working
I noticed that I had to run my drier twice to dry my clothes. So I pulled it out and started to feel the vent hose to see if it was clogged. Then the hose came off the back of the drier and a bunch of water came out. I tilted the drier back to try to get any water out that might be inside. With the hose still off I tried to start the dryer and it would not start. I checked the plug and its in the outlet like its been. I have no idea what I did or why there was water. I would appreciate any help.
    Genius:
  • 1,028 Answers
Water indicates vent issue as far as not starting there is a thermal fuse mounted to element housing it may be out also be sure door is fitting and shutting ok
Posted on Jul 24, 2008
Why is my drier not getting hot and taking longer to dry clothes
the vent hose may be crimped or clogged. remove the vent hose off the back and feel for hot air. Hope this helped tim
Sep 07, 2010 | GE DVL223EBWW Electric Dryer
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
My dryer gets hot but does not dry efficiently. Clothes are still very damp after more than 1.5 hours. I noticed that the lint trap is not really gathering any lint.
your problem might be in the actual vent to the outside. If the vent to the outside from the drier has a clog and will need to be cleaned. Without the proper ventallation the clothes will not dry. I suggest pulling the drier out and removeing the vent hose that connects to the outside and clean it. Once this is done you shouldn't have any problems
Hope this helped
Dave
Feb 23, 2010 | Whirlpool LER4634J Electric Dryer
It takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Dec 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryer model DE27CW1 takes forever to dry a small to med loads. 3 hours for 6 towels on a manual high heat setting. The dryer vent has been cleaned and A&E Service has been here twice and said the dry...
I think you are clogged.
Pull the machine from the wall ... remove the hose and run the hose of a vacuum (shop vac if you have one) into the machine. When you are sure that is clean, turn around and clean the hose ... or better yet - replace it. Lastly, dont forget the outside vent.
With the drier empty, turn it on to air and see what kind of air movement you get out of the exhaust.
Another thing yhou might want to check is the sensor in the drum (this would apply if you have a sensor based drying system. ) The sensor may be covered with some material that prevents it from reading the dampness of the clothing.
and one more thing ... you do have heat ... right? Gas? - you should see flame in the burner - electric, does it heat up at all? It is not beyond the realm of possibilities that your heater is done ... but check the easy stuff first.
I hope this helps you
Let me know what happens
a
Oct 15, 2009 | Dryers
Slow drying time
very simple, do this test, take your vent hose off the back of your dryer, now dry a load of clothes, if it still takes a long time to dry, then you may need to replace your thermastats, if it works better, your vent hose was pushed in, or smashed or the vent from the wall to the outside is clogged.
thanks Whites appliance repair
Sep 07, 2009 | Kenmore 659 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer not drying
try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Jan 16, 2008 | Amana NDE2335AY Electric Dryer
Lint screen caked up
Take the vent hose lose at the back of your drier, and clean your lint screen off or replace it, then try drying some clothes. If this technique minimize or eliminate the caking of your lint screen, then the problem is in your vent hose. Clearly, there is an obstruction, or an improper installation of your vent hose.
good luck
Jan 15, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 80 series dryer...takes twice as long as it should to dry
no about all the time this kind of problem is caused by some kind of vent restriction start by looking over th back of the drier with a flash light and see if the vent is mashed folded over on its self or too long you only need enough to hook to the connector to the floor then go to the out side with the drier running and check to see if the drier hood attached to the house is opening i some have a plastic screen attached to the hood to keep critters out make sure that's clear rule is must have a 4" opening from drier to out side hood cant hang down under house and come back up as dryer will fill it with water over a peorid of time now easy way to verify vent restiction is to disconect vent run 1 load and see if it dries in proper time about 60 min
Dec 31, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
