Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Hi, If this is electric then you have a burned out element...
if this is a gas unit,,,
Your problem could be or probably is with the regulator...not enough gas
pressure...
I am sorry we are not allowed to send info through the mail
But as a rule of thumb
potatoes (any type 375%)
chicken and fish 325% to 350%
In most cases when deep frying...when it floats its done! should be a golden brown....fill oil to top of fill line
Good luck and Thank you for using FixYa.
he product has been recalled in canada you can find more information on the government health and safety website here: http://www.healthycanadians.ca/pr-rp/recall-retrait_e.php?langCd=eng&searchTyp=1&re_id=466&searchstring=&searchyear=2008&searchcategory=&StartIndex=1
Some Deep Fryers heat up faster than others, please see details below for pre-heating times:
Non-Immersion Element (No element in the Oil): 25 to 30 Minutes
Immersion Element (Element in the Oil): 7 to 10 Minutes
Are you by any chance overloading the fryer? try smaller batches.
Preheat the oven to 180 to 200 F.
Heat the oil in the fryer to 280 or 290 F. In small batches appropriate to the size of the fryer (fries for a serving of 4 people may need to be divided into 2 or 3 groups), fry each batch for about 8 minutes at this temp. Remove to a holding bowl. They will look limp, nasty and oily. (This uses 1/4" square fries from baking pototoes cut with a standard mandoline.)
When all the fries have been precooked, increase the oil temp to 375 F. Add the fries back to the oil in the same sized batches as before. It will take 3 to 5 minutes for them to crisp and brown. Drain, salt, and move to a cloth-lined bowl and hold in the 180 F. oven. Let the oil temp recover to 375 F. and cook the next batch in the same manner. Repeat, holding interim fries in the 180 oven, until all the fries are done.
When all batches are done, toss to distribute salt and the new fries with old, and serve immediately. Properly done, all commercial french fries pale in comparison to these.
However, I cannot guarantee that this method works with frozen commercial products. I always use fresh baking pototoes. That said, the frozen product should work to its optimal advantage when done in small batches with the first batches held in the warming oven as the other batches are done.
If it still doesn't reach 300 F then by all means take it back to the shop and ask for a replacement. If you're out of warranty get an estimate for a repair.
Good luck and bon apetite ;]
