Question about Sony KP-61V45 61" Rear Projection Television
Sony color rear video projector KP-43HT20
I turned the TV on one day and the picture was distored. The color is off. There is a blue and red out line around the picture and around the words on the screen. The picture almost appears as double. Any suggestions?
  • Anonymous Jan 11, 2009
    seve distorcionada la imagen de color rojo sony projector de video kp 43ht20
    Genius:
  • 2,920 Answers
Get the tv degaused that should fix the problem
Posted on Aug 17, 2008
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
I have a sony projection tv kp-43ht20 and the picture has gone pink. Can you give me an idea what has happened? Is this a fixable problem? I can't afford a brand new tv at this time. Thank you for your...
Sounds like the convergence is out of adjustment....moving the set can cause this as well as components chaging value with age....The kp43ht20 is an older set and may not have the alignment setup in the menu as with the newer sets...but you can go thru the menu to find out...if there is one, then you can try to align the convergence...usually there will be a crosshatch on the tv...when aligning convergence there will be a blue setting and a red setting...you want to select red first and try to get the lines lined up as close together as possible on the red adjustment..then you go to the blue adjustment and do the same...the outcome should be as close as possible to white when everything is lined up properly
Dec 30, 2010 | Sony KP-43HT20 43" Rear Projection...
Sony Projector Color Display
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-57HW40 57" Rear Projection...
Colors don't line up, and screen is distorted on a sony KP43HT20
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Dec 08, 2009 | Sony KP-43HT20 43" Rear Projection...
Sony KP-53V25 Color Rear Video Projector Powering off unexpected
possible crt problem, they have to be reseated, if not then the convergence is failing expect to pay around $300-350
Jul 26, 2009 | Televison & Video
Distored 3d look colors overlaping each other
Replace Convergence output ICs in TV to solve problem.
Jul 03, 2009 | Sony KP-43HT20 43" Rear Projection...
Blue and red color are off, picture is not clear
convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Televison & Video Logo
310 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
