Salton RA10 10-Cup Rice Cooker
Problem for Salton RA10 10-Cup Rice Cooker
How do I use the
By yolandehouse on Jul 23, 2008
how do I use the salton ra10 rice cooker.
Best Solution
posted on Jul 24, 2008
Helpful)
MINormal
Rank: Apprentice
Rating: 93%, 3 votes
It came with a small plastic measuring cup. The ratio for that is 1 cup rice to 1 cup water (using the measuring cup for both items). Measure out your rice first, BUT for best results you need to rinse your rice several times (I do three times or until the water is fairly clear). Place rinsed rice in cooker and add equal amout of water . You can also add in your butter and salt at this time if you wish. put lid on cooker,plug it in and push the little lever down (it'll click). It will cook for about 20 minutes and the lever will pop up on its own. Don't do anything yet! you need to wait about 10-15 minutes more, or at least until the steam stops before you open the lid. The rice should be cooked perfectly.
There will (with this model) be a light brown crust on the bottom of the pan, butthe instruction manual said that it was a normal occurance (but it is a buggar to get that off-soaking for a couple hours helps).
I really like using rice cookers because they do a great job in cooking the rice. I hope this clarified how to use this model.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Salton RA10 10-Cup Rice Cooker
Questions and Unsolved Problems for Salton RA10 10-Cup Rice Cooker
Do you recommend Salton RA10 10-Cup Rice Cooker?
Answer
Answer
have george forman steamer with no manual of instruction
Answer
Gaggenau steam oven displays f14 error code
Answer
the lid is 'broken' on our salton 10 cup rice cooker. the vented hole used to have a piece that let... (More)
Answer
How do I go about finding and ordering a replacement lid for my Salton Rice cooker Model # MJRA10AB?... (More)
Answer
control moves to warm before rice is done and after a while won't go to cook when pressed
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Rice Cookers... Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
