Panasonic Palmcorder PV-DC252 Mini DV Digital Camcorder Logo
Posted on Feb 12, 2011
Does the pv-dc252d support recording on to sd card with video?
5 Related Answers
Anonymous
  • Posted on Dec 23, 2008
SOURCE: Is there any way to record a video onto the sd card instead of tape?
You can't. SD card is only to take images in this camera.
Anonymous
  • 3 Answers
  • Posted on Mar 12, 2009
SOURCE: download PV-GS39 cam recorder drivers
Hello. I also have the PV-GS39. I had the same problem as you have, here is what I DID to resolve my problem.
1.Go to: http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D
the above link will take you RIGHT to the web page to download the PV-GS39 Software & Drivers that YOU WILL HAVE TO HAVE. But if you have WINDOWS VISTA then you can use the WINDOWS MOVIE MAKER software that is ALREADY PRE-INSTALLED on your PC then you will NOT have to download the software from the above link.
2. You HAVE TO have a: FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD. I got mine at: Best Buy for: $53.86 with taxes. the name of this card is: DYNEX FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD.
3. You ALSO hae to buy the CORD that connects to the PV-GS39 and the DYNEX FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD, the cord costs $36.79 ALSO at Best Buy.
I did ALL 3 of the above and now I'm copying my movies and videos from my tape in my camcorder onto my PC and BURNING the video onto DVD/CD Disks.
If you have any questions, you can email me at: [email protected].
Sincerely,
Rick D. Michaels
Anonymous
  • Posted on May 08, 2009
SOURCE: Can you record video to the SD card on the Panasonic NV-GS25?
Yes very easy with a razor sharp knife you will need to cut it in middle.
When you did that you will have this [ ] [ ] if you put in the right part you will record video to sd card and the left side will put pictures on sd card , when ur done just put them together with some tape again and same thing next time
Anonymous
  • 4 Answers
  • Posted on May 12, 2009
SOURCE: How can I record on the SD card on my Panasonic NV-GS230?
did you check the manual
Anonymous
  • 56 Answers
  • Posted on Jul 02, 2009
SOURCE: I recorded a video on my samsung sc-dc 164
how did you transfer the video from the card to your PC?
did you connect the camcorder to your PC or did you use a memory card reader?
if you can play the audio then what you need is the right video codec for the unit
try searching for video codecs through search engines
make sure that the software that you are using to play the video plays the file format of your video,
try using roxio, then connect the camcorder to your computer via USB, make sure that the drivers are installed, play the video through your camcorder then use roxio to capture it real time instead of the usual "copy-paste"
I have a pv-gs29. Mini palmcorder, records fine. Can't figure out how to transfer to tv or recorder,can see any ports at all on this thing, what if anything am I missing
Spec list from CNET :
Panasonic PV GS29 Specs
As you can see, it has both USB and Firewire connections - or else you could just remove the SD card and put it in a card reader.
My lexar sd 4G card won't work in my camera? says card error in card record mode?
The PV-GS36 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot it will not work properly. You need to use SD cards, 2GB and smaller.
Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
5helpful
Can i record video on my sd card
I don't think so. I just got mine and read the instruction book backward and forward. Recording video on your SD card is not an option on this model, just taking pictures.
Storage path
On removable memory cards. Panasonic iPalm Digital Cameras are equipped with an SD Card Slot which allows the camera to store images on EITHER an MultiMediaCard (MMC) or an SD Memory Card. Simply insert an MMC or SD Card into the camera, take pictures until the card is full, then remove it or replace it with a fresh card. You can selectively erase any or all of the images from the either the MultiMediaCard or the SD Memory Card and reuse it. Storage capacity for the PV-DC3000-A (based on included 16MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 13 images Fine Mode (2048x1536) up to 27 images Normal/2x Digital Zoom Modes (1024x768) up to 69 images Burst Recording Mode (1024x768) up to 82 images 3x Digital Zoom Mode (640x480) up to 150 images Motion Image Recording Mode (12 sec. max./320x240) 9 sets TIFF Mode (2048x1536/no compression) 1 image Storage capacity for the PV-DC3010 (based on included 32MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 29 images Fine Mode (2048x1536) up to 57 images Normal/2x Digital Zoom Modes (1024x768) up to 145 images Burst Recording Mode (1024x768) up to 172 images 3x Digital Zoom Mode (640x480) up to 315 images Motion Image Recording Mode (12 sec. max./320x240) 19 sets TIFF Mode (2048x1536/no compression) 3 images
Storage path
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
