Question about Finis Swi MP3 Player
My computer does not recognize the device.
It was working fine, i did the normal routine of clicking on safely remove hardware. but then, the red light kept flashing fast on my swim mp3 player and then it switched itself to the green light flashing fast. now, i cant turn it on or off. what should i do? i tried rebooting my pc and plugging it in again, but it still says the device has malfunctioned. pls help me
    Problem Solver:
  • 10 Answers
I had the same problem with my ipod shuffle.I can't tell you how to fix it now but i will later.But i can tell you what happned. Sometimes when you use Ares or Itunes it can crash it,corrupt it or it just needs to be restored.If you cant wait for me to tell you then you can check Google because they'll have solutions. :D
Posted on Jul 23, 2008
Cefc d33193
Often when this happens, the drive was removed without "Safely Remove Hardware" . Try different computers (Operating Systems) and when recognized, Use the "Safely Remove Hardware" key. Then try it on your laptop.
Oct 12, 2013 | Computers & Internet
My 10 inch netbook wont recognize new hardware(wireless mouse through usb port
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top bottom
or you might use the safe mode option
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red X right update driver
hope this helps
Nov 20, 2011 | eMachines eM250-1915 Netbook
I plug in the flash & my MAC computer computer does not see it...nor can I find it..but when removed...it says that device was not removed properly...please help....Thank You Jilli
im not sure about a mac computer but i no with windows you should remove the hardware safely device when removing any hardware if you finally get it back right click and see wahat options are there in windows the safely remove hardware is a small arrow on the bottom right of the screen
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
this is for windows im not sure about mac computers
hope this helps
May 22, 2011 | Computers & Internet
Touch pad does not work
  1. Shut Windows down.
  2. Power the unit on, and start tapping the F8 key. Keep tapping the key until you get the Windows Startup Menu.
  3. Choose Safe Mode from the list.
  4. Once in Safe Mode test, the device to see if it is working.
  5. If the device works in Safe Mode, but not in normal Windows mode, it may be a software issue.
  6. If this is the case, open up my computer and go into control panel.
  7. Open Add/Remove programs, and remove any mouse related software listed here.
  8. Reboot the computer.
  9. If it still does not work, right click on My Computer, and choose Properties.
  10. Click on the Device Manager tab, and make sure View Devices By Type is selected at the top. (NOTE: If you are running Windows 2000, Device Manager can be reached by clicking on the Hardware tab.)
  11. Look for a category named Other Devices. If it is there, click the plus next to it, and remove all devices listed under it. Remove the device by clicking on it once to highlight it, then click on the remove button at the bottom.
  12. Now Look down through the list and find the Mouse category.
  13. Remove any devices listed below it by highlighting the device, and choosing remove at the bottom.
  14. Reboot the computer.
  15. If the two pointing devices stop working after removing the mouse driver. Just use the Windows key on the keyboard to bring up the start menu. Now use the arrow keys to highlight Shutdown on the menu. Press the Enter key to select Shutdown from the list.
  16. Power the unit back on, and let it boot up to Windows normally.
  17. When it gets back to Windows, the New Hardware Wizard should appear and load the required drivers for the mouse.
  18. Test the device now.
  19. If the device still does not work, call WinBook Tech Support for further assistance.
  20. Or if the device doesn't work in Safe Mode or normal Windows mode, then it is most likely a hardware issue. At that point call WinBook Tech Support for further assistance.
Nov 03, 2010 | Acer Aspire T690 (AST690UP820A) PC...
Remove printer drivers
You can check your laptop further by booting it from Safe Mode. To boot your computer in Safe Mode, try to tap continuously F8 function key on your keyboard immediately when you start your computer. It will lead you to an Advanced Menu from where you can choose the option "Safe Mode" and hit enter to boot your computer to safe mode. Now try to check the display driver in the device manager (Control Panel >System > Hardware >Device Manager) If it is not there, try to reduce the screen resolution and reboot your computer to the normal mode. If you are still getting the blank screen in Normal mode, try to boot computer back in Safe Mode and try to restore your computer to earlier time when it was working fine for you. To do so click on Start Menu > All Programs > Accessories > System Tools > System Restore. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next. On the Select a Restore Point page, click the most recent system restore point in the "On this list, click a restore point" list, and then click Next. Now confirm the restoration and click on Next to complete the restoration and follow the wizard.
Cheers!
Mar 28, 2010 | Acer Aspire One AOA110-1588 Notebook
When im tapping my touch pad it doesnt work
Just above the pad is a small button, make sure that has not been accidentally pushed, that is the power button for the touchpad.
Oct 04, 2009 | HP Pavilion dv7-1245dx Notebook
Computer does not recognize CD/DVD drive
If updating the drive firmware does not work, then replacement of the drive will be necessary.
Jan 30, 2009 | HP Pavillion ZV6000 Notebook
I have a Toshiba Laptop with Windows Vista and when I go to the speaker on the bottom right corner and click on it it shows a little red X that says no audio output device is installed. It was working fine...
To begin, let's open up the Device Manager. In Windows Vista, go to Start, Control Panel and click on the System and Maintenance link. Next, click on the System link and then on the left hand side under the Tasks pane, click on Device Manager. That will open a window that lists all of your computer's hardware. You'll see all of your computer's adapters, ROM drives, your keyboard, your mouse, the controllers, the USB ports, etc.
Now, let's get back to the question at hand. If you've been having trouble with the drivers for some of your computer's hardware, there are three common issues that come into play. Chances are, your problem lies within one of them, so let's get down to it!
1.) Certain Hardware is Not Listed - The first problem arises when hardware you expected to find is not listed. If something is left off the list, it's likely the hardware was not installed correctly. In that case, you should power down your computer and find the actual hardware device. Take some time to make sure it is hooked up correctly and then restart your computer. Once you do that, Vista should automatically recognize the hardware and it will go through the installation process again. You may be asked for the hardware's drivers during the new installation, so just make sure you have those ready to go as well. When the installation is done, you should now see the hardware listed under the Device Manager.
2.) You See a Yellow Exclamation Point - It's possible that when you get the Device Manager open, you'll see a few entries that have yellow exclamation points next to them. When that happens, it means the hardware is installed correctly and Windows recognizes it, but it's still not working properly. This type of thing usually involves a driver error, so you just need to update your drivers. To do that, right click on the hardware (the one that has the exclamation point next to it) and choose Properties. Next, click on the Driver tab and then the Update Driver button. From there, click on the option that says "Search automatically for updated driver software." Vista will then look for the correct updated drivers for your hardware device and install them for you. If Windows can't find any, you will need to go to the manufacturer's Web site and download them there.
3.) The Dreaded Red X Appears - If you have a hardware device with a red X next to it, you're dealing with a disabled piece of hardware. To fix that, simply right click on the hardware and choose Enable. That will start up the hardware and you can begin using it like normal once again.
That's it! Working through all of these troubleshooting techniques should fix your hardware issues within your Device Manager
Oct 10, 2008 | Computers & Internet
IPod Nano not recognized when plugged to USB
Make sure your not pluged into a USB hub. It will work if its plugged directly into a USB port on your computer.
Jul 14, 2008 | Apple iPod nano
Phillips Go Gear 6GB
The Phillips website has a solution for this:
Go to the FAQ for this mp3 player. It'll tell you to install the Device Manger which will repair the problem. I've done this, however, the Device Manager claims my mp3 Player is not connected.
Try this yourself, you might have better luck.
Oct 27, 2007 | Philips HDD1630 MP3 Player
Finis Swi MP3 Player Logo
719 people viewed this question
Top Finis Audio Players & Recorders Experts
Are you a Finis Audio Player and Recorder Expert? Answer questions, earn points and help others
