One speaker jack on my behringer PMX 2000 amp is not working. IT seems to have a short and the sound comes in and out as I move the speaker chord. Can the jack be replaced?
  • 682 Answers
Yes you will find your jack in radio shack near you or nearest electronic store
Posted on Jul 23, 2008
How do i hook up my laptop and my tablet to a behringer Europower PMX 2000
Easy to do - just get a patch cord that has a stereo 1/8" plug on one end and two phono (RCA) plugs on the other end. Plug the phono plugs into the "Tape IN" jacks on the mixer and use the "Tape" volume to adjust the sound level. It's best to turn your laptop or tablet volume up to maximum, then adjust the volume on the mixer.
Jan 15, 2015 | Behringer Audio Players & Recorders
How do i connect a Behringer 1202 mixer to a Behringer B215D Powered speaker
Looks like both units accept 1/4" jack & I think the 1202 is unbalance out, so just use a standard screened mono (i.e. 2 pole "TS") jack to jack lead & you should be fine. Good Luck! :-)
Jul 28, 2014 | Behringer B215D Powered Speaker (550 Watts...
Will my Behringer amp purchased in the USA work in Australia
You will probably need a voltage converter. Unless you purchased the general export model with a switchable voltage power supply, your PMX2000 will have the power supply for the 120V 60 Hz electrical mains and a 10A H fuse. To confirm this, look on the back of the amp.
I wish that I had better news for you.
Jul 19, 2013 | Behringer Audio Players & Recorders
I have a behringer pmp 1280s. I was running two speaker and two monitors through it. One of the monitors was kicked and the patch cable to it was bent. I smelled smoke and the sound coming through turned...
That's a bad sign. A dead short in the output results in a short of the audio output transistors. I believe that to be the problem and a fairly simple fix to someone good at soldering BUT, you can't get parts for behringer equipment. Most components are specially made for behringer. I've been working on an amp for 6 months and I can fix it BUT, I can't find the parts anywhere, or can even find any reference to them online. Without a reference to the specs, I can't even get a generic replacement. Check your music stores in you area, a behringer dealer may can help you.
Mar 03, 2013 | Music
Nady PMX-600 powered mixer problem with no sound
Intermittence is usually an issue of a loose connection - whether it's in a cable, inside a speaker, inside the mixer, or power-related. I would check them all, starting with the audio connections.
Feb 24, 2013 | NADY PMX-600 Powered Mixer
Having problems connecting speakers via a power amp in to my behringer x2222 usb mixing desk - im not getting the ins and outs correct :(
I had a like problem with a crown amp. I found it was in the amp settings , nothing to do with the mixer set up. We had it a mono setting. Take a look at your amp set up book, i'll almost bet thats where the problem is
Dec 06, 2012 | Behringer Xenyx X2222USB USB Audio Mixer
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
There is no sound being sent to the speakers and
Check if sound to headphone jack is normal. If so, try the headphones in the MAIN out 1/4 inch jacks. If there is sound (it will be a lot less as this is a line level output), then the power amps are probably popped... and maybe the main power supply. The auxilary runs all the visible stuff.
If under warranty, take it for repair. Behringer doesn't provide schematics so working on these is a problem. In the PMP5000 there is a chronic problem of insulation breakdown on the rear most amp that can wipe out the power supply as well as the switching transistors in the amplifier. (This is a class D switching/ energy recovery type amp).
Feb 21, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer pmx 2000 missing knob
If the shaft broke, then you will have to replace the whole encoder for it. You cannot glue a shaft and expect it to hold.
Mar 17, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Behringer PMX 2000 Amplifier
Hi aliciacarol,
The best place to go to get parts for Behringer parts I have found is straight to Behringer themselves, or an agent nearest to you. They are generally inexpensive to buy, and delivery are better than most. Steer your way to your nearest agent to you from the map . If you have any troubles, feel free to get back to me here. Good luck, thanks for using FixYa
regards
Graeme
Feb 23, 2008 | Behringer EUROPOWER EP2500 Amplifier
Open Questions:
46 people viewed this question
 Grubhead
Grubhead
