No sound from speakers of cambridge audio a1 amplifier
  • 682 Answers
Start with reset(power off and then power on)-if you see power light on-check your input source(mic or dvd or other)-check your speaker cables for short or open circuit after that check speaker itself-if you confirm that all outside amp is ok.and still not working you will have a problem in amp internal circuit.(if you have speakers button in your amp do not forget to press it.)
Posted on Jul 23, 2008
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Jan 05, 2016 | Audio Players & Recorders
Why does my Cambridge Audio Azur 851W power down even when a signal is operating.
amps like this only power down when there is a problem with the amp, usually a shorted output stage, but could also be shorted speaker wires or damaged speakers, it's a self protection mechanism
do you get sound from both speakers before it powers down?? if you do it is definitely an internal problem so take it to a repair facility,,,
if not check the speaker cables & the speakers themselve
Feb 22, 2015 | Cambridge Audio Audio Players & Recorders
Cambridge audio 640a problem, olume goes to zero, I hear a little bang on speakers, light starts blinking!
This sounds like there's an overload in the main amp section. Often caused by a short-circuited device.
Oct 06, 2014 | Cambridge Audio Azur 640A Amplifier
I have a Cambridge audio turntable which looses sound quality about halfway through record, as though it looses one of the channels (on the right hand side). I've tested the speakers, the amp, even had it...
Might be a weak relay or transistor in that channel, they both will stop and reset when overheated. make sure you're ready to test it when it does this again, this may help you locate the bad component. I'm leaning towards the transitor, because they also amplify sound signals in radio frequency.
Oct 06, 2010 | Cambridge Audio Azur 340A 2-Channel...
Low volume through amplifier
Turntables generate a very low signal. Phono inputs on receivers containa pre-amp section to boost the signal to "line level" or the same level as other audio devices. I would suspect that you need to add that pre-amp section. Phono preamps are available for around $20 or so and are inserted between the turntable and the standard audio input on the receiver or amp.
Hope this helps,
Dan
Apr 15, 2010 | Cambridge Audio Azur 540A Amplifier
I have cambridge audio azur 640a amp. Problem I have is only the one speaker is working. Both speakers seem to be ok working off the left speaker terminal. Seems to be problem with output from right...
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
Dec 29, 2009 | Cambridge Audio Azur 640A Amplifier
153 people viewed this question
 Grubhead
Grubhead
