Question about Video Game Consoles & Games
Fan stopped working on PS3. overheats in 10 minutes and shuts off.
3 Suggested Answers
SOURCE: ps3 fan doesnt work?
I carefully opened my ps3 as the fan had gotten stuck, the way the fan is designed, (Large 4 inch or so) required a reseat ( push the fan back down to the motor) The way it's designed is that if the ps3 tips from vertical over to horizonal rather roughly the fan becomes displaced, I gently pushed the fan back down and it was free as a bird again, max cool. I think if the system is tipped over frm vertical, too many times roughly tha fan would probably be worn out, so I'm shopping for a back up. A aftermark external would probably work too, But remember though the internal fan is a stepper motor, if the cpu thinks it's not rotating.. cool or not it will probably indicate failure and resume a shutdown condition... best of luck PS have a spare fan on hand...
Posted on Jul 11, 2008
  • 7 Answers
I have solution for all of you. You need to call sony at 1-800-345-7669. They will send you a box so you can place you unit in (ps3). If you got warrany on your ps3 they will ask you to send in a copy to varify that it is still in warrany. If it is then they will not charge you anything they will open up the system and see what the problem is either fix the ps3 or they will replace it with a refuribished one. Also you need to make sure that the warrany tag on the ps3 upper right side is still there or they will charge you 150 dollars. And if the serial on the back is removed they will not even service your unit. If you unit is not in warrany they will charge you 150 dollars. Wich is real good because they will dust the interior of it good luck everyone...
Posted on Mar 20, 2009
Dryer runs for three or four minutes then shuts of and willnot start for 10 minutes or longer'
Could be motor overheating and shutting off. Need to check if drum turns freely. If it does check vent hose making sure it isn't plugged causing dryer to overheat. If motor is bad it will get worse and just not start
Sep 24, 2014 | Avanti D110 Electric Portable Dryer
Our HC 6800 projector will work for about 10-20 minutes before displaying a solid red screen and shutting off.
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the top cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Mitsubishi HC6800 1500 ANSI Lumens 3LCD...
I have a cs1205 electralog heater. after 5 minutes we hear a pop and the heater stops working. we shut it off and will hear a pop then turn it back on. it will work again for about 5 minutes. what is wrong...
I have an electralog cs1205, when i turn it on, although it works , after about 10 seconds it makes a strange noise. It never did this before. Any ideas on whats wrong?
Nov 27, 2010 | Dimplex Compact Electric Flame Stove...
Our PS3 was freezing all the time so we hadn't played in months.Installed new hard drive. Reformatted it. It played for about 5 or 10 minutes, then froze again. Turned it off. Started it again: The light...
the ps3 has a tendency to overheat in enclosed spaces. put it in an open area, and run a small fan on it. there are usb fans that you can plug into the console to help circulate air around the system.
good luck
Dec 01, 2009 | Sony Playstation 3 (PS3) Console
My system starts up fine, all icons act properly.. but after playing for fifteen to twenty minutes, it locks up. Then when I reboot it starts like a pixel seizure eventually whole screen turns into lines...
if there's pixilation problems only after 10-20 minutes, i'd say the gpu is overheating.
Now the real problem is if the gpu has been damaged due to the overheating and whats causing it to overheat in the first place.
The heatsinks on the ps3's are crazy so i'd push more towards the gpu failing, but it could be just a simple overheat problem.
They sell external fans for the ps3 that connect to an external power source. Try purchasing one of those, it will run you 30 bucks.
If it continues after that i'd push more towards the gpu's been damaged and your going to need service on it.
Hope this helps.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
My internal fan quit working and i am now using fans that are around the house to keep it cool. know i was playing a game for like 3 hours straight and i went and watched a movie and it froze about 20...
Does the PS3 work again afterwards?
Do you still have control of the PS3 when the movie freezes; can you fast-forward/skip past the point it stopped.
If the movie freezes at the exact same point again, then it is a defect with the DVD, or is dirty/scratched.
if the PS3 is still working at all.. REPLACE THE FAN NOW! It should be quite simple. while one PS3's CPU may be able to handle overheating a thousand times and never break, another PS3 may overheat once and permanently destroy or weaken the CPU!
If the fan is just dirty, you should be able to open it, rebuild the fan by removing the (probably) sticker on one side and using a pin to pop off a retaining washer.. then you can push the fan blade off and clean the bearings and everything with isopropyl alcohol. put JUST one or two tiny drops of oil on the bearings/shaft and reassemble.
There may just be a hair inside. Often, fans have rubber o-rings inside -you SHOULD remove these as they will ALWAYS eventually stop the fan from working again if they've failed once before already.
If the fan is actually dead (quite rare) then you can purchase one online. Get an exact replacement, or one with the same measurements and either the same, or better, specifications (will be written on the fan, and can be searched online -important that the new fan moves as much CFM cubic-feet-per-minute of air)
Aug 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 overheat
Your PS3 might have a broken fan. If you are using an external fan that attaches to the PS3 than stop, fans like the Nyko Intercooler and Pelican cause more problems with ventillation and may cause the PS3 to overheat. If heat is an issue make sure the system has plenty of room to breath and point a small fan at the console. If thiat doesn't work call Sony customer sopport.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
101 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
