Question about Brother MFC-410CN All-In-One InkJet Printer
Machine error 46
Machine has stopped mid way through a clean, and says refer to maintenance in user guide. unfortunatley i have'nt got a user guide.
Any suggestions on where i go from here?
  • 5,660 Answers
Advise you go to Start>Hover your mouse cursor on All Programs>Over to Brother>Go down the list until you come to MFC-410cn. There is also a Help section in the list.
Posted on Apr 15, 2009
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
My printer says it's unable to clean 46? it's a mfc printer LC-51 Series ink
Please note that this error code appears when the container in the printer that is responsible for storing used / discarded ink is full or registers as full.
The following instructions will guide you through the process of resetting the printers self clean counter so the error will go away but in the event that the ink absorbing box is actually full and this is not an erroneous message the error message will trigger again immediately.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Also please note that if the ink box is full and the error code is reset the printer may begin to spill out excess used / discarded ink.
I suggest purchasing a new ink absorber box and installing it.
May 04, 2011 | Brother MFC 420CN All-In-One InkJet...
Error 46 what is it
Here is the answer to your MFC code 46
Nov 24, 2010 | Brother MFC-5840CN All-In-One InkJet...
Clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Apr 09, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean refer to maintenance guide 46
Hi
Thanks for using FixYa. Printer error 46 indicates that the ink absorber pad is full and required to be replaced by an authorized engineer. To resolve the issue please contact Brother Customer Service from "Contact Us" on their website—
Error 46 solution
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
Machine error 46
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C):
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
Carry on printing !!
thanks.
Jul 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer flashes "Clean Unable 46 - refer to troubleshooting and routine maintenance in User's Guide". I went to the user's guide and did all the maintenance/cleaning that was reccommended. Nothing cha
Try resetting the purge counter:
1) Enter machine maintenance mode (on MFC240C all fourphoto/copy/fax/scan lights flash in maintenance mode). Care is neededin maintenance mode, otherwise critical settings may be inadvertentlycorrupted.
FAX models with numerical keypads:Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if youfail to complete the correct key sequence within two seconds, press theStop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys.Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenancemode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the loginformation list to reach the purge counter. The purge counter is the25th item in the list.
Jun 02, 2009 | Brother MFC-3360C All-In-One InkJet...
Not printing
Nov 21, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-410CN All-In-One InkJet Printer Logo
100 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
