Question about Xerox Office Equipment & Supplies
I have the Phaser 6200 and ghosting images are starting to appear on everything. I would say that about one third of the top part of the page is being reprinted very faintly at the bottom of the page. How to I get rid of this?
  • Anonymous Mar 06, 2009
    We have ghosting with our 6200dp. Imaging unit is 1 year old and 60% good, new fuser, new transfer roller. xerox tech suppor recommend to change again the imaging unit or pay $350 for the first 30 minutes + $65 for each add 15 minutes. How interresting? Can anyone help?
    President:
  • 2,072 Answers
Most likely you need to replace the fuser. The teflon coating on the heat roll wears, when it does some of the ink sticks to the roller and winds up as a "ghost" image across the page.
It could be your imaging unit. But more likely is the fuser.
Let me know please.
Posted on Jul 23, 2008
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
The print always prints one page when I turn it on
You have to go into the menu and turn off the Start Up Page and/or the Configuration page.
Feb 02, 2010 | Xerox Phaser 6200N Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Mar 10, 2009 | Xerox Phaser 6360/N Printer
Printing Problem, Xerox Phaser 6200
XEROX 6200 DP Printer doesn't print from DOS base program in windos XP. Printer is connected with parallel port
Oct 25, 2008 | Office Equipment & Supplies
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
Repeating defects appearing on every 3rd page
That most likely is on the transfer belt assembly, You can look at that belt and see if the defect is a mark that may be cleanable or actual damage to the transfer belt, which would require replacing the transfer belt.
Jun 02, 2008 | Xerox Phaser 6200DP Laser Printer
535 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
