Question about Lexmark Office Equipment & Supplies
What type of usb cable is required for lexmark printer, model?
    Guru:
  • 1,049 Answers
Standard USB cable. They're all the same.
Posted on Jul 23, 2008
Is this printer wireless? or do I have to use the usb cabl to print?
it seems that wireless is not supported, and you must use a USB cable. Check that the connectors are the correct ones; printer accepts a type B ('house') male connector (plug)
If uncertain consult Lexmark support, or the manual for this printer. Information (including probably a manual) can quickly be obtained from the webpage
All Products Printers MultiFunction Lexmark X2650 Lexmark
The image shows two connectors (which may be on either end of a single cable, and what I think you need) lower is type B (printer end) , upper is type A (computer end, most commonly). Available in various lengths, you need USB 2.0 spec.
Apr 10, 2015 | Lexmark X2650 All-In-One InkJet Printer
How do i connect my lexmark x1150 to windows 8
Just connect the Printer using USB cable to the Computer once Connected. Please follow the below mentioned steps:
1. Click on the Start Button on the Keyboard.
2. Just type Add and go to the settings Options.
3. Click on the add device option.
Then Windows 8 will search your Printer and Install the driver which is required.
Good Luck!
Apr 09, 2013 | Lexmark X Office Equipment & Supplies
What kind of usb plug i need for lexmark8350 to hook my pc
The USB cable would be the standard A/B cable. the port on the back of the printer, is located under the phone line jack. Open the attached URL for the setup guide.
http://www.lexmark.com/publications/pdfs/8300/eng/setupsh.pdf
Mar 16, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
Can you connect a printer lexmark x 2760 without a usb?
The Lexmark X2670 can only connect to a computer using a USB cable. Without it, your computer won't be able to communicate to the printer for printing, copying and scanning. If you lost the USB cable, you may purchase one from any retail stores. The USB cable used for your model has Type A plug on one end and the other end has Type B plug. You may also contact Lexmark Technical Support Center for additional assistance.
I hope this information has been helpful.
Jan 15, 2012 | Lexmark X2670 All-In-One Printer
ALL IN ONE S305 USB does not seem to work , i cannot press continue to install onto network , its a new usb B male to male ?
The Lexmark S305 printer uses a USB type A on one end and type B on the other. Type A end goes into your computer and type B end goes into the printer. Make sure the USB cable is properly inserted.
Jun 05, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
What type of power cable is required for P915. thank you. I just have a USB.
Lexmark P915 requires 25 Watt HV Adapter (220 - 240V AC, 50/60 Hz) in HV countries OR
25 Watt LV Adapter (100 - 127V AC, 50/60 Hz) in LV countries.
So, you have to buy a power supply as per above specification.
In case the cable marked at '2' above is missing, you can find/ use a similar cable, which can be purchased from a local computer store.
Lexmark P915 Setup Guide
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | Lexmark P915 InkJet Photo Printer
Lexmark X2470,all in one.what usb is required,as it is not supplied
Printer conncection cables are not always included; this is something to watch for when purchasing new printers.
Lexmark sells a USB (2meter) cable for use with their printers. It has a Type A connector on one end (connects to computer) and a Type B connector on the other end (connects to printer).
See here:
http://www.lexmarkshop.ca/product_info.php/info/p547_USB--2-Meter--Cable.html?XTCsid=8uf9jfg007037lui6nbrrvkko5
You should however be able to purchase a suitable cable at your local supplier; there are also on-line suppliers who are very reasonably priced.
Try to stay under 10 feet or 2 meters in length as ask for a cable with a Type A and and a Type B connector for use with an USB printer interface.
Trust this is helpful. Please vote.
Dec 29, 2010 | Office Equipment & Supplies
What is the serial or model information for the USB cable for the x5150
The printer USB cable has Type A on one end and a Type B on the other. But you can also contact Lexmark Technical Support to request for that. They might send you one for free. If you contact them, give the USB cable part number: 43H5856. Hope this helps.
Jun 21, 2010 | Lexmark X5150 All-In-One InkJet Printer
CANT INSTALL NO Ubs CABLE AND THE DISK IS HAVING A PROBLEM WORKING
Most printers do not come with data cables - either USB or Parallel. You have to get one for yourself ok. About installation, for most USB printers, you don't need to attach to the pc before copying the drivers to hard disk. If you had done that already, you put back the driver cd into the drive tray and then uninstall. You'll have to connect the printer via USB cable only when prompted and allow to detect the printer and complete the installation process by itself ok. Just select the recommended installation type and it will run automatically. Good luck
Jun 03, 2009 | Lexmark X2600 InkJet Printer
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
