TOSHIBA TV MODLE CX35D89 SERIAL NO.7564592 E6755
MY TV HAD NO SOUND IT TAKES A WHILE 4DSOUND TO COME IN NOW ITS TOTALLY GONE AND HAD A VERTICAL LINE ON D SCREEN WHAT COULD BE D PROBLEM IS IT AN IC
    Genius:
  • 1,139 Answers
Hello joan_tinglin,
It could be the audio integrated circuit. I would advise that you check the output of the audio circuit before saying that for sure. In addition check the power supply since that to can cause audio problems as well as video problems. If possible can you post a picture of the screen with the problem present. This will help in the diagnosis of the problem.
Thank you,
Shuttle83
Posted on Jul 24, 2008
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
My TV's video is out. A straight line goes horizontally along the screen. The sound is fine. It use to come and go, now it is gone for good. Does a tube need to be replace?
Hello.Theres a loose connection in your CRT board of your television.The problem is in vertical section maybe the vertical output IC is cold solder.Thats why harizontal lines appear in the screen of your TV.Your picture is good the problem is in the CRT board at the vertical section.
Jul 03, 2011 | Toshiba 27A45 27" TV
The picture with my television has gone out. The sound is fine but there's only a white line across the middle of the television. How can I fix the picture?
The Toshiba sets are well known for this problem, the tv has a vertical deflection issue caused by the vertical ic and a few small capacitors going bad, I recommend a tv technician for the repairs.
Jan 15, 2011 | Toshiba 36A40 36" TV
9 year old Toshiba TV. The picture is totally
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Jun 25, 2009 | Toshiba Televison & Video
Thin horizontal line with a Toshiba CF3062A
This is a problem with the vertical circuit that is usually a defective vertical IC. This part costs $10-$20 and is easily replaced. Sometimes there are capacitors in the same circuit that need to be replaced as well. Dan
Jun 09, 2009 | Toshiba Televison & Video
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Tv toshiba vertical problem
I had white lines 4" thick vertically for about a week, then one day powered the unit up and with in 3 seconds there was a loud pop from the rear or the unit. Any one know what needs to be replaced?
Jan 23, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
Nov 27, 2007 | Toshiba 50HP95 50 in. Plasma Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
