Question about Microsoft Windows Vista Ultimate Edition
Microphone i tried that already, i uninstalled the driver, then i let it reinstall when it checked for new drivers or whatever that step is called and then it still doesn't work
    Brigadier General:
  • 10,406 Answers
Which motherboard (manufacturer? model-number?) do you have?
Which sound-card (integrated onto motherboard? separate PCI card?) do you have?
Are you plugging the microphone into the "pink" socket on your sound-card?
Posted on Dec 03, 2009
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
Will Not Play a Music CD, Will Not Burn Music downloads ,Messege" connect Burner " ?? Burner is already installed .
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 02, 2011 | Lenovo 42Y9354 CD-RW Burner
My webcam isnt working
Go to this site: http://www.msimobile.com/default.aspx
From there choose the products dropdown box at the top left....
locate your laptop model. From there if you go into the page of your product, they have "Driver/Manual Download" buttons for the models.
Click that and find the driver for your webcam and try to reinstall it.
They may have an update to your existing driver that will help.
You can also go into the device manager in Windows and "uninstall" the webcam by right clicking, and then reboot your machine to see if Windows automatically reinstalls the driver using plug and play.
Good Luck
Apr 19, 2011 | MSI Computers & Internet
It will only print one page, shows status of printing but dosn't continue to print. I checked the settings and the are correct. I try to canel the print jobs but they won't canel unless I reboot my...
You need to install the latest drivers for your printer. Is your PC VISTA operating ?
First step is to uninstall the software and reinstall the latest drivers from the given link below.
Dell V305 Drivers
If the issue does not resolve even after uninstall/reinstall, try the steps below and it should fix the issue,
This is usually caused by corrupted printer drivers. It's most often seen after an upgrade from a previous operating system when the printer was kept connected and turned on during the upgrade.
Solution: Completely Uninstall and Reinstall your Printer and 'force' XP to see new drivers
Dont forget the step 4
Step 1 Disconnect the printer from the PC
Step 2 Go to the Control Panel and click on Add/Remove Programs. Highlight any Printer Software that is listed here. Select Remove.
Step 3 From the Control Panel, click on Printers & Faxes. Right click the printer in question and select Delete
Step 4 Look at the Toolbar. Select File, then Server Properties. Look in the Drivers tab. Highlight the printers drivers listed here and click on Remove for each one.
Step 5 Reboot the PC. Do NOT reconnect the printer!
Step 6 Go to the website of your printer manufacturer. Look for new XP drivers for your model. Download the correct software. If there are no Windows XP drivers for your printer, try looking for ones for Windows 2000. In most cases these will do almost as well.
Step 7 Run the exe file you just downloaded. It should auto-start the installation program
Step 8 The software will tell you when to connect the printer.
Step 9 Once the software is installed and the printer connected, try a test page. It should be feeling great now!
Regards,
Ron
Feb 15, 2011 | Dell V305 All-In-One InkJet Printer
Epson workforce 600 prints with no black. Have installed new cartridges, cleaned heads numerous times, uninstalled/downloaded driver/reinstalled -- still no black printing.
new ink carts, cleaned heads, reloaded drivers ?
hardware issue, you already performed troubleshooting needed for this issue (try calling tech support and same steps will be provided)
better check your warranty or ask for repair options
Apr 07, 2010 | Office Equipment & Supplies
My cdrom drivers are corrupt in the registry but when I uninstall and then reinstall is says that the most up to date drivers are already there
When you right click on the device to uninstall it, make sure to check the small box that includes deleteing the driver software along with the device itself. This forces the computer on startup to search windows update for the new driver.
Nov 26, 2009 | Office Equipment & Supplies
My dell v305 printer won't print. commumition problem. I have done everything to try and solve problem. help
hi there!
-you need to uninstall and reinstall the program of the printer, if you have already done it. you may try the step below but it will still ask you to uninstall the printer software.
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: NOTE: Be Exact on the File Directory ! HKLM = Hkey Local Machine -Click Start then type REGEDIT then press Enter -Delete any items under HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
Oct 24, 2009 | Dell V305w All-In-One R840635AU InkJet...
Re: microphone
Are you still having this problem?
Jul 23, 2008 | Microsoft Windows Vista Ultimate Edition
Scanning documents
basic steps:
1. Check all connections to make sure they are all seated properly.
2. Uninstall and reinstall the software.
3. Uninstall and reinstall scanner drivers.
4. Check manufacturer's website for updated drivers
From your description I would say try steps all the following steps in order, but it sounds like the device drivers might be the problem (but always try the simple stuff first.
May 16, 2008 | HP PSC 1350 All-In-One Thermal Printer
Microsoft Windows Vista Ultimate Edition Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
