Random red stains appearing on clothes. Aeg Lavamat 50430
  • vic king Jul 25, 2008
    Have checked for trapped articles and clothing behind heater void. No luck so far. The stains appear possibly more like spots maybe of the rust/oil type possibly generated by bearing breakdown. They will not come out with any spot removers.Could this be the source even though I have checked for noise (nothing audible on rotation) there is a little end float at which time the drum clonks a little. Many thanks for your previous reply , it gave me the confidence to investigate further.
Door rubber is turning black with use. does not seem to affect opertion but it does smell a bit!
Posted on Apr 12, 2010
    President:
  • 1,462 Answers
Possible you have some red clothing in the gap between the tub and drum - there is nothing in the machine to cause red stains
to check, remove rear half of cabinet, remove heater (held by 1 10mm nut which just loosen and prize out heater) you can then see into the gap between tub and drum. shine in a torch and rotate drum by hand to see if you can spot anything. disconnect from mains first
Posted on Jul 23, 2008
  • douglas smith Jul 26, 2008
    quite fgeasible that bearings are breaking down or more likely the lip seal before the bearings. if this is going, the bearings will not be far behind
    doug
I want to soak my washing because of bad stains. But I don't know how to with an aeg lavamat washing machine
Pick your cycle, add clothes and detergent, switch off once filled and all the soap has dissolved. Turn back on tomorrow :>)
Dec 13, 2016 | AEG Washing Machines
I need a motherboard for a aeg lavamat l62622
I have an AEG WITH ERROR CODE C9 IT WONT SPIN OR WASH ,COUNTS DOWN THE CYCLE ,FILLS BUT CLOTHES ARE LEFT A STICKY MESS ,MOTOR AND BUSHES ARE FINE ,I HAVE RESET NUMEROUS TIMES BUT STILL GOES TO C9 ANY IDEAS
Feb 26, 2010 | AEG Washing Machines
PUMP PROBLEM
The problem you have can be caused by something inside.. clothes blocking the outwater, or metal or something blocking the pump.. soulution: clean it..... Take away gum (the gum betwin pump and machin). Clean/take awway clothes and etc from inside... there can also be something in the gum... check it! and check the pump to.
Jan 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Washing machine-dryer AEg
it could be the drum bearings going
Nov 05, 2007 | AEG Lavamat 72640 Front Load Washer
Does not spin when inserting 5.5kg clothes ,only when decreases weight
I'm not a technician, but I own a AEG Lavamat. As far as the owner manual says, this washing machine doesn't allow more than 5 kg.
Jan 12, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
175 people viewed this question
Top Washing Machines Experts
