Chances are that the blower resitor is faulty. Look for a square panel about 2in by 4in with a plug on it.located on blower housing, when removed you will see 3 metal springs and 1 resistor. I think to check it with ohm meter on each side of spring and resistor. current should flow both ways I think.Part is cheap and easy to replace
Its
faulty blower motor resistor. The low and medium speed on blower motor is
controlled by resistor and its actual speed is high. So because resistor is not
working, blower motors actual speed which is high is working.
It
can be faulty blower motor or faulty blower motor resistor. Get the blower
motor inspected. If it's faulty it has to be replaced.
For
blower motor testing and replacing, check the link below: ----
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
