Question about AOpen F50PS (Black) 15 in. Flat Panel LCD Monitor
F501JS 15 "MONITOR WITH BUILT IN SPEAKERS.
I CAN NOT GET SOUND. PLEASE HELP
Soundboxen do not work how can i find the drivers for it and how to installed it
No driver is needed for the built-in speakers to work. The built-in powered speakers work the same as a desk top powered speakers system.
You just need to ifind out if it is the amplifiers in side the monitor are bad or it is the sound card problem in the PC.
Feed the monitor with the sound source such as the MP3 player to see if you can get any sound from your monitor.
If it does not work then the problem is inside the monitor, but to have it repaired will be to expensive, you will be better off spending the repair money on a good set of powered desk top speakers system instead.
Please leave rating if it helps.
Jan 05, 2011 | HP Pavilion F1523 15" LCD Monitor
Cant hear sound from monitor
the monitor does not have speakers built in - you'll need separate speakers for sound.
Jun 03, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Powerpoint 2007 get sound from one monitor to another
Some monitors have speakers built-in, some don't. The sound never travels through the 15pin d-type VGA connector. If the monitor has sound, there will be a small 1/8 inch stereo jack in the back or bottom of the monitor. Most all laptops have a headphone output jack (again 1/8 inch stereo) which is perfect for patching to external amplified speakers or to a monitor with speakers built-in. This patch cable can be purchased at Radio Shack, Best Buy, etc etc.
Oct 25, 2008 | Toshiba Satellite A135-S4527 Notebook
HP vs 15 the built in speakers echo
Do you have a microphone? If you do, and it is near the speakers, it will echo a lot. Also, check your soundcard settings. If there is an option for room ambience or environment effects, make sure you have them disabled.
Jul 14, 2008 | HP vs15 15"LCD Flat Panel Monitor
No sound from built in speakers
the built in speakers on the monitor are only speakers, they are not run through the video signal cable and have to be connected separately.
many monitors with speakers provide a stereo cable in the package but dont tell what the cable is for.
If there is a cable provided there will be a small jack on the monitor that connects to audio out on the sound card.
There may also be a stereo plug combined with the video cable, that likewise connects to audio out.
If the hardware is connected, there may be a volume control on the monitor that may be muted.
If the problem is a recent thing for a system that previously had working sound with this monitor, try the mute on the audio settings
Jul 12, 2008 | HP vs15 15"LCD Flat Panel Monitor
No sound from the monitor
Plug the monitor speakers into a source of constant sound (mp3/cd player) and make sure the monitor is not muted and volume is at least half way.
If that works adjust the volume and mute settings on the computer
Mar 08, 2008 | Liquid Video E15LCD1 15"
Speakers will not work
plz check sound with speaker if there is sound then u can check or change cable that you are inserted in monitor plug .if it is ok then problem is related with monitor sound ckt plz change ic related with sound section
Mar 04, 2008 | Balance CM2015 15" LCD Monitor
Sound
Check if the sound is enabled on your PC then check for wiring that goes to the monitor.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Dec 11, 2007 | Relisys TL 766 Monitor
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Installed new monitor, lost my sound
If your previous monitor had built in speakers and your new monitor does not you are going to have to purchase new speakers. If your new lcd monitor has an audio input you can purcahse a sterio mini jack cable for under $10 at any store that sells computer stuff (circuit city, best buy, walmart, target, etc). Simply plug one end into your monitor and the other end into your computers audio output jack (usually color coded green). Now of course if that monitor does not have built in speakers your only option is to purcahse a set of speakers for the computer. These usually start at around $15.
Aug 10, 2007 | LG Flatron MW-30LZ10 30" LCD Monitor
AOpen F50PS (Black) 15 in. Flat Panel LCD Monitor Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
