Question about Sharp Office Equipment & Supplies
Error code L3-00 on Sharp AR-507 copier - Sharp Office Equipment & Supplies
ginko
  • 19396 Answers
SOURCE: have a sharp ar-336 copier
Chech this link
Posted on Apr 15, 2008
SOURCE: I have a Sharp ARM350N
it is scanner out of position, swich off then swich on it should reset it.
Dave Moore
right document solutions
02074664700
Posted on Jun 04, 2008
checkitright
  • 1362 Answers
SOURCE: My Sharp AR-336 copier gives
when you turn on the machine it rotates and takes severaal readings from different sources. one of them is for the drum, adjusting the seperation to the age of hte drum. So as the drum ages with the amount of copies it automatically adjust it self. Have the tech replace that sensor (if they haven't done so) or maybe it just has toner on it giving false readings.
http://www.copier-help.com/copier-help/ecs/sharp/ecssf2216.html
Posted on Aug 07, 2008
  • 257 Answers
SOURCE: error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Posted on Dec 02, 2009
  • 3 Answers
SOURCE: IS there a reset code for a Sharp AR-507 copier,
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
Posted on May 18, 2010
Is there a reset code for a Sharp AR-507 copier, error H2-00?
May 04, 2010 | Sharp AR-507 Copier
Error code h5-01 appeared on my sharpmar-507
Dec 02, 2009 | Sharp AR-507 Copier
I want to connect my ar-507 gray digital copier to pc UBS port
Did you use a pcl driver? What was the error message?
Nov 19, 2009 | Sharp AR-507 Copier
How can I get the error codes of my Sharp AR-507 and how to clear
Press the "P" key, the "Interupt" key, the "C" key then the "Interupt" key.
Once you enter the Simulation Mode, then "2,2, start (Print Key) will show the jam, service counters, and 2,4 start (Print Key)"will allow you to clear the counters.
To clear certain codes, once you enter the Simulation Mode, then enter "13 or 14 or 15 or 15 then start". Depending on the code will depend on which "number" you need to execute. (It doesn't hurt to do all the numbers."
Aug 08, 2009 | Sharp AR-507 Copier
Sharp AR-507 code E7-00
ICU Communication error. Could be a problem with the ICU board or the connection between it and the PCU board. If resetting the machine (main power off and on) does not solve the problem you'll likely need a service call from a copier tech.
Oct 07, 2008 | Sharp AR-507 Copier
L6-10 error on startup with Sharp AR-507. Any help?
L6-10 LSU error??»??»??»??»??»
Repair for!
Sep 03, 2008 | Sharp AR-507 Copier
99 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
