Question about Maytag M6Y18F7A Air Conditioner
Maytag AC says EE
My display reads EE Help!!!
  • redpepper6 May 11, 2009
    No matter what I do the display still reads EE. Not cooling, nor does the fan work. Nothing.
3 Suggested Answers
kstfas
  • 75 Answers
SOURCE: EE in the display window
Hi, I have been trying to get in touch with a service rep to find out but unable to get one. They wanted proof that I had purchased a unit. Its possible that your receptacle is not polarized right. By that I mean the two wires may need switched on the receptacle or maybe it doesn't have a good ground. You may want to try temporarily using an extension cord and try another plug. Most things will run good on receptacles wired wrong but with a computerized AC it may be seeing a fault. If you still need help I think the best way to find out would be for you too contact the store that you bought the unit from and make it their responsibility to find out what the EE stands for. If they cant, get the unit replaced and try again. If you do get hold of a service tech # from Maytag, please send it to me at kstfas@yahoo.com Hope this helps. kstfas
Posted on Aug 28, 2007
heatman101
  • 43501 Answers
SOURCE: The Maytag a/c unit model
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
The Maytag a/c unit model #M6Q10F2A has been working fine until this morning. The display reads "EE" and the a/c does not work. Unplugging the unit does not help.
heatman101
Aug 29, 2010 | Maytag M6Q10F2A Air Conditioner
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
My air conditioner turned itself off and now the display reads EE we have unplugged it it runs for a little while then shuts itself off again
Remove the unit from the window,and dissassemble and use a water hose and clean the inside of the unit,remove all debris,this is most likely the problem.
Jul 10, 2010 | Maytag M7Y15F2A Air Conditioner
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
FUJITSU AIR CON
fujitsu tech line # 866-952-8324 very good ac dan
Aug 01, 2008 | Fujitsu Heating & Cooling
Maytag error message EE
What is the name and model number of your unit?
Jun 10, 2008 | Maytag M6Q10F2A Air Conditioner
Wont turn on. EE on display
It's probably the control board inside the control panel. I had the same problem and it moisture shorted out the board. You can order a new one from Sears Parts for about $45
Jun 09, 2008 | Maytag M6Y12F2A Air Conditioner
Aug 27, 2007 | Maytag M7Y10F2A Air Conditioner
EE IN TEMP DISPLAY
I just called a maytag repair store, and they just had one in the shop, it sounds like the control panel has died, and will need to be replaced. They cost around 60 dollars, + install fee.
Jul 05, 2007 | Maytag M6Q10F2A Air Conditioner
Maytag M6Y18F7A Air Conditioner Logo
87 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
