Question about Dryers
My Kenmore Solid State, Heavy Duty Plus dryer will not start
5 Suggested Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
most problems with dryers not heating is the thermo fuse is blown. bout 20 buck to replace it looks like a small white flat football. but most likely if it went out that means the the high temp thermostat is messed up too
Posted on Feb 07, 2008
  • 1122 Answers
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
  • 97 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
  • 1810 Answers
SOURCE: Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Posted on Aug 04, 2009
Kenmore heavy duty plus dryer modle number 886573130 works fine just stopped heating up.
Gas dryer no heat means the heating element broke or fell apart, need to install new one, go to sears hardware and order a repacement....model # in hand.
Feb 22, 2015 | Kenmore Dryers
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty solid state dryer, mdl 1108609420 (???) Starts and all functions work as long as the Start Lever is held up. As soon as you let go of it, the dryer stops. Unable to locate...
repairs should be performed by a authorized repair person.if there is not enough voltage to the relay start switch from the electronic control replace the control. if there is enough voltage to the relay start switch replace the switch.
Jun 04, 2017 | Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Trying to find kenmore elite heavy duty king sizecapacty plus ultraquite pac gas clothes dryer mod#11o72082100
It is no longer produced. Try eBay or craigslist?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 74602 Gas Dryer
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start.
Aug 04, 2009 | Kenmore 700 6972 Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
