Question about Whirlpool Duet GHW9150P Front Load Washer
Moving I am moving to a new house and was yold by 3 moving companies that I need a moving kit to safely move my whirlpool duet washing machine. However, no one seems to know what this is, how to get one or how to install it...any help???
    President:
  • 1,462 Answers
You just need to refit the transit bolts which you removed when you had machine new. if you have lost them, pack some polystyrene blocks between tub and cabinet so the assemby is held tight
Posted on Jul 23, 2008
Code f 71
Check to see whether the laundry drum to the washer moves. If it does move, then the user interface needs replacing. If the drum is locked and will not move, you need to replace the central control unit on the washer.
Read more: Whirlpool Duet Error Code F71 ' eHow.com http://www.ehow.com/facts_7618431_whirlpool-duet-error-code-f71.html#ixzz1AANUprMm
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Vibrating Front Load Washer
probably not. did you just move in? have you always had it upstairs? the only way to make it so your house does not shake is to reinforce the floor.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer gets badly out of balance and makes a racket and moves
The most likely cause is a bad or broken balancing spring and or shock absorber connecting the drum to the washing machine housing.
Mar 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We moved our whirlpool duet washing machine to do some work in our laundry room. we moved it back and put a load in and it's making a loud humming noise during the cycle. what could be wrong. we turned it...
You may have dislodged the suspended innards from shock mounts that keeps some nose from escaping. I would remove the back panel and inspect the insides to see if one or more corners of the suspended assembly are now out of place.
Nov 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9200 Washer door lock issue
no thiis is normal operation, it is considered a child safety feature. in case a sleeping child should happen to be in machine, the short 2 sec blast of cold water will wake them and give them a chance to exit before the machine starts washing.. all whirlpool frontloaders do this, thats how it waas explained to us at factory training.
Dec 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moving my washer & dryer
find the original shipping stuff the long plastic dowels can be reinserted and if i remember right there is a bolt or pin that goes back through them to hold them in place.. if all else fails you may try removing top and shoving thick quilts down sides and back between drum and cabinet ..remove bottom and put something under tub to prevent a lot of motion up and down on the shocks and springs ..hope this helps i'm in repair not delivery so i seldom see the shipping materials if its not a long move just careful handling may be enough
Aug 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
830 people viewed this question
Dan Webster
Dan Webster
Sal De
